  1. Jun 22, 2021 at 7:45 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No kidding, same weight and all?
  2. Jun 22, 2021 at 7:55 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    So far the tundras custom radiator is holding up.
    guess I’ll be calling them for the Tacoma. THey even call once in a while to make sure it’s all good still.
    04Pre_Runner[QUOTED] likes this.
  3. Jun 22, 2021 at 8:03 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I do not know
  4. Jun 22, 2021 at 8:05 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    04Pre_Runner likes this.
  5. Jun 22, 2021 at 8:08 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    @Kwikvette is currently out camping and asked for help.. he's with half a bar of service so can't use the internet.
    Being a good Samaritan he offered to help a 2012 bmw 750 IL with a "low" tire by lugging his viair over from his 4R. Tire's fucking flat flat and they can't find the spare. With me reading through bimmer forum posts i learned that, that particular generation, were equipped with run flats from factory and "ShOulD ONLy UsE RUn fLaT TIrEs" so no spare option... also BMW offers a fix a flat can accessory, however it's not standard and must be purchased when the car was new :rofl:
    He said its got both a hole in the tread and gash in the sidewall (barely holding on) so I don't know what the bmw owner thinks fix a flat is gunna do him.
    that's why I run 20+ year old rigs with nothing bigger than 15s cause I want sidewalls tall enough I can patch that shit with gorilla tape and rubber cement:anonymous:
  6. Jun 22, 2021 at 8:12 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Those top ones and there is a set that rams use that are kinda similar are some of the best looking wheels for a modern full size. Better then even most aftermarket wheels
  7. Jun 22, 2021 at 8:33 PM
    Wulf
    rock raisin
    Yeah the ones I'm grabbing are the top style. Maybe they'll make my truck look a little newer without being over the top.
    Sperrunner[QUOTED] likes this.
  8. Jun 22, 2021 at 8:46 PM
    Josharmstrong98
    Josharmstrong98 Member
    Josh
    1996 taco 5spd 4x4
    I'm new to toyota trucks, just picked up a 96 tacoma 5spd 4x4 with the 2.7, has quite a bit of blow by and the coolant looks muddy, no smoke out of the exhaust and oil level is fine but cranks a long time before starting, any ideas what it could be
  9. Jun 22, 2021 at 8:48 PM
    Empty_Lord
    Dan
    I’d do a leak down test on all 4 cylinders.
    Wulf likes this.
  10. Jun 22, 2021 at 8:48 PM
    eon_blue
    Azusa, CA
    Yeah my mom had a BMW for several years that came with those run flat tires, no spare. When she got a flat that actually resulted in a flat, she had to call via the satellite car link to BMWs assist feature and have them send someone out with a new one. And those tires are crazy expensive.
  11. Jun 22, 2021 at 8:50 PM
    eon_blue
    Azusa, CA
    Muddy coolant doesn't sound good. How hot does it run? The dummy temp gauge on the dash isn't a real good indicator unless it's seriously overheating.
  12. Jun 22, 2021 at 8:50 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
  13. Jun 22, 2021 at 8:58 PM
    Josharmstrong98
    Josh
    1996 taco 5spd 4x4
    It's takes a minute to get it to start but once it's does is idles rough and clears up pretty quick, they it runs as it should, temp gauge sometimes stops working but when it does work it's reads dead center
  14. Jun 22, 2021 at 9:06 PM
    Abeyancer
    Jimmie
    PNW
    Fork that! I totally understand (but don't agree with) most new cars not including a spare.. but not even a can of run flat+inflator? Seems silly to me
    I never understood the appeal of run flat tires.. maybe because I've been able to patch a hole in the tread since a little kid
    eon_blue[QUOTED] likes this.
  15. Jun 22, 2021 at 9:08 PM
    Abeyancer
    Jimmie
    PNW
    Temp gauge in the center doesn't mean really diddly regretfully. Best to get a scanner that can tell temp while running
  16. Jun 22, 2021 at 9:08 PM
    Empty_Lord
    Dan
    I HATE MOUNTING RUNFLATS. seriously. They’re a total pain in the ass. Our AWD siennas have them.
  17. Jun 22, 2021 at 9:09 PM
    Empty_Lord
    Dan
    Tour991[QUOTED] likes this.
  18. Jun 22, 2021 at 9:15 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I remember that cause you asked me about removing the clip haha. Long screwdriver or bent needle nose are the only ways.
  19. Jun 22, 2021 at 9:17 PM
    Tour991
    James
    South Reno/Tahoe
    Yeah to bad the guy selling it is a crack head.
    Wulf and Empty_Lord[QUOTED] like this.
  20. Jun 22, 2021 at 9:17 PM
    Empty_Lord
    Dan
    Normal
    Wulf likes this.
