  1. Jun 26, 2021 at 6:01 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    I just noticed that the bushing in that picture doesn't have the metal sleeve in the center. Did you remove it already?
  2. Jun 26, 2021 at 6:35 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    It fell out
  3. Jun 26, 2021 at 6:35 PM
    JKO1998
    Utah
    Maybe I’ll take them off and take them to a shop to have pressed out
  4. Jun 26, 2021 at 6:36 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    New UCAs
  5. Jun 26, 2021 at 6:40 PM
    6P4
    Colorado Springs
    I also tried that. The shop took some gouges out of my arms that bothered me enough that I got new (used) arms and re-did the work myself. You'll probably have better luck than I did... It's a good way to go if you're using OEM bushings.
    If you're using OEM-style aftermarket (like Moog), take a look at just buying new arms with bushings already installed. It might be cheaper than having a shop press them.
    EDIT: The shops I called estimated $60-80 to press the bushings, but reserved the right to charge more if they put up a fight.
  6. Jun 26, 2021 at 6:42 PM
    JKO1998
    Utah
    I’m thinking a torch is probably the way to go, just leave the shell in there
  7. Jun 26, 2021 at 6:43 PM
    6P4
    Colorado Springs
    What new bushings did you get? Sorry if you said already... I didn't see anywhere.
  8. Jun 26, 2021 at 6:45 PM
    JKO1998
    Utah
    Energy suspension or whatever
  9. Jun 26, 2021 at 6:46 PM
    6P4
    Colorado Springs
    Ah, for ES, you should ignore most of what I said. Torching out and leaving the shell is 100% the way to go.
  10. Jun 26, 2021 at 6:57 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Fat and fatter say hi
    And my kids
    And this bastard thinking he can bogart my food
  11. Jun 26, 2021 at 7:03 PM
    JKO1998
    Utah
    guess that means I have to finish taking them off the truck….
    Tomorrow’s activities
  12. Jun 26, 2021 at 7:49 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    "Dammit, I got caught"
  13. Jun 26, 2021 at 7:50 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    lol the junk Vulcan engine ate 3 out of the 4 valve shims on one head
    I was hoping to have enough spares to shim the new engine but I think I'll have to order a few. The motorcycle shop wants $13 ea
    Running Board Man likes this.
  14. Jun 26, 2021 at 7:50 PM
    Wulf
    rock raisin
    Boop the snoots
  15. Jun 26, 2021 at 7:51 PM
    Wulf
    rock raisin
    RAM RANCH
  16. Jun 26, 2021 at 7:51 PM
    0xDEADBEEF
    Hmmm. What diameter are they? I might actually have a few at my parents house for my klr.
  17. Jun 26, 2021 at 7:53 PM
    Wulf
    rock raisin
    9.48mm
    I have some swapping and checking to do but if the stars align on paper I will only need a singular 2.40mm shim
  18. Jun 26, 2021 at 7:54 PM
    0xDEADBEEF
    Oh. Nevermind. KLR shims are 29mm
    Wulf[QUOTED] likes this.
  19. Jun 26, 2021 at 8:00 PM
    Wulf
    rock raisin
    Thanks anyways:)
    0xDEADBEEF[QUOTED] likes this.
  20. Jun 26, 2021 at 8:58 PM
    Speedytech7
    I always do.
    :confused:
