  1. Jun 27, 2021 at 9:29 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Yeah, I haven't had ADS do a revalve yet. Probably won't until it's time to rebuild them. Rear coils make things a little different from rear leaf springs too. The HD springs I have in the rear do a much better job than the overloaded stock springs I had before, even without the sway bar.
  2. Jun 27, 2021 at 9:34 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    What's funny is, I have the correct sized bits but never bothered to buy a stronger drill to run the long bolts and sleeves.
    If you're going to run a winch, do it.
    If not, don't bother.
    I had planned on a winch but not for some time which is why I still have those bolts, sleeves, etc. new in package in case you mess up and need a second set.
    01x4[QUOTED] likes this.
  3. Jun 27, 2021 at 9:35 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'd leave the sway bar on a coil sprung solid axle especially if you have sway bar swingers like Toyota usually do... Then it really isn't restricting travel much if at all
    CS_AR likes this.
  4. Jun 27, 2021 at 9:37 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Front sway bar is long gone. Rear sway bar was a huge limiter of rear axle travel offroad. Hence looking at installing the Antirock setup in at least the rear.
  5. Jun 27, 2021 at 9:39 AM
    Speedytech7
    Did your rear not have the swinging rear mounts? Maybe they stopped doing it, but on my LC the rear bar mounts to the frame on a balljoint so it can control oscillating motion without restricting droop or compression.
  6. Jun 27, 2021 at 9:40 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Longer links wouldn't help?
    I only have my rear on due to my panhard bar angle, but consider running 2G4R links as they're longer than my current ones.
  7. Jun 27, 2021 at 9:52 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Nope, no swinging mounts. Solid mounted just like the front.
    Even with longer end links, I wouldn't get the full travel that I get now. Longer links only allow you to keep the ends of the bar closer to parallel to the ground and don't promote travel. It's fine without them. Like @Speedytech7 with his first gen, I probably need to have the shocks revalved some for the truck to improve things any further.
    Without the rear bar. Couldn't even get close to that travel with the rear bar on there, even with longer links.
    CS_AR likes this.
  8. Jun 27, 2021 at 9:56 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah, I know for sure droop is limited on mine cause of the bar.
  9. Jun 27, 2021 at 10:09 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Yeah just randomly, googled it and it's a manufacturer defect. No software issue or of the sort
  10. Jun 27, 2021 at 10:11 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Found some palm trees in the middle of the regional park today
    Tour991 and Kwikvette like this.
  11. Jun 27, 2021 at 10:39 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I did,
    just gotta get a bigger hammer to get the uca off the spindle, then find a torch
  12. Jun 27, 2021 at 10:44 AM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    I'm just throwing it on sans winch right now, so I guess I can drill em later. Thanks man.
    I got last minute invite for a week long trip so I'm in scramble mode now haha.
  13. Jun 27, 2021 at 10:46 AM
    01x4
    Sounds fun.
    I went and looked at mine earlier...tight squeeze
  14. Jun 27, 2021 at 10:47 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  15. Jun 27, 2021 at 10:49 AM
    JKO1998
    Utah
    Probably easier if you took the battery and air box out, but I don’t have that time to waste
  16. Jun 27, 2021 at 12:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  17. Jun 27, 2021 at 12:07 PM
    JKO1998
    Utah
    How do you guys like your bushings?
  18. Jun 27, 2021 at 12:22 PM
    JKO1998
    Utah
    Bone apple teeth
    Running Board Man likes this.
  19. Jun 27, 2021 at 12:34 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    They made the leaf pack slightly thicker, but more importantly they increased the thickness of the pads between the leaves in an attempt to counteract the squeaking complaints
  20. Jun 27, 2021 at 12:36 PM
    Abeyancer
    Jimmie
    PNW
    Thank you for the part numbers!
    I ordered the entire kit from HeadStrong cause I didn't wanna piece it together.. figured they knew what was up better than I however their sales person just ordered the bushings for the greasable shackles they knew from memory based off the old kit I figure
