  1. Jul 8, 2021 at 6:49 AM
    Running Board Man
    Running Board Man Well-Known Member
    The 1st gen rav 4 could be optioned with one
  2. Jul 8, 2021 at 6:51 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    LOL..
    Well, that nipped it in the butt.
    Not to forget tit bits.
    0xDEADBEEF[QUOTED] and Abeyancer like this.
  3. Jul 8, 2021 at 7:01 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Most units around here seem small than this one, but probably not I guess.
    CS_AR[QUOTED] likes this.
  4. Jul 8, 2021 at 7:37 AM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    I see your old stripper getting pumped dry and raise you one horizontal new new courtesy of Precision.
  5. Jul 8, 2021 at 7:38 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Well two days in a row of working on the Tacoma, maybe I'll make it three. Doing all the fitup work on the frame reinforcement is tiresome but it's straight forward at least. Anyone have a good product for stripping the stock frame paint quickly. Seems to load up flap discs and wire wheels aren't quite strong enough unless is all rust... And my truck isn't quite Indiana levels of toast.
    Das it mang likes this.
  6. Jul 8, 2021 at 7:42 AM
    JKO1998
    Utah
    I guess I’ll have to call you with a picture of the cyclone rig
  7. Jul 8, 2021 at 7:44 AM
    alee891
    Austin
    Black Hills
    Tacomaless
    Don't get blown up around that thing :rofl:
  8. Jul 8, 2021 at 7:45 AM
    JKO1998
    Utah
    Yea, we don’t want that
  9. Jul 8, 2021 at 7:50 AM
    alee891
    Austin
    Black Hills
    Tacomaless
    Their track record is something to look up if you haven't already been informed.
  10. Jul 8, 2021 at 7:54 AM
    JKO1998
    Utah
    I guess I better go make sure it’s cyclone first
  11. Jul 8, 2021 at 7:57 AM
    alee891
    Austin
    Black Hills
    Tacomaless
    Obnoxious baby blue painted rig = Cyclone
    Abeyancer likes this.
  12. Jul 8, 2021 at 8:00 AM
    JKO1998
    Utah
    Well that answers it
  13. Jul 8, 2021 at 8:02 AM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    @se7enine (not sure why the message isn't quoting right now, weird.)
    Yeah I remember seeing that heat chart. Now I'm just trying to figure out the reason. Fluid seems fine, no leaks underneath either.
    My RPMs for gear changes seemed a bit higher as well. Might be my imagination but when I tap the throttle it shoots up quick, more so when I'm low speed (feels more sensitive). Has just seemed off on this trip. Only thing done the day before leaving was having the shop fix my AC. (Which is also making an annoying humming noise I need to figure out, doesn't seem to be the blower motor, sounds outside of the cab and is throttle responsive)
    (Just checked oil too and its a little bit low.)
    Just got home and storm is a comin' so no work outside today.
  14. Jul 8, 2021 at 8:04 AM
    Speedytech7
    Low isn't ideal, but make sure your TV cable is properly adjusted too. There's a little ferrule crimped on and it's supposed to be "x" amt exposed from the rubber sleeve to show proper adjustment
    01x4[QUOTED] likes this.
  15. Jul 8, 2021 at 8:09 AM
    01x4
    Okay thank you, I'll check that. Didn't even think of it.
    (Any rule of of thumb for how much exposed?)
  16. Jul 8, 2021 at 8:22 AM
    Speedytech7
    Looks like this pic says it all for the A340
  17. Jul 8, 2021 at 8:23 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    I saw pix posted by Lifeguards of the Oceanfront over the holiday.:eek:
    :confused:o_O:alien::alien::alien:
    Evidently lots of people forgot to learn how to swim before going into the OCEANo_O
    And thousands more need lifesaving on the boardwalk:crazy::homer:
    :lalala:
  18. Jul 8, 2021 at 8:28 AM
    Speedytech7
    Thissun too
  19. Jul 8, 2021 at 8:39 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @04Pre_Runner
    You installed a transmission cooler on your Taco right?
  20. Jul 8, 2021 at 8:45 AM
    01x4
    Awesome, thanks again for these.
    Not enough time to dig in but I ran out and had enough time to open the hood and check the throttle cable, feels a little slack to touch, and tested idle real quick, its about 1200 at start and takes a few minutes to get down to 675 or so. Throttle response seems a tiny bit hesitant too, but the rain started so I had to come in. Will continue when Elsa blows by.
