  1. Jul 15, 2021 at 7:27 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I doubt that will be detectable TBH, it modifies the running code for sure, but unless they're running full checksum hash checks on ECUs (would require a published list of every checksum of every ECU, which isn't feasible) it shouldn't be detectable since the OVT uses the same version codes and naming conventions as stock tunes.
  2. Jul 15, 2021 at 7:29 AM
    eon_blue
    Azusa, CA
    Yeah I read on another forum theyre basically looking for the less advanced tunes that render the vehicle 'not smog ready', which I doubt the OVT one does
  3. Jul 15, 2021 at 7:29 AM
    Speedytech7
    We dumped a can in my buddy's 22RE just cause, and it stopped blue smoking on hard accel, but it had oil control ring issues, the compression was fine before so we never checked after. Never did cut open the oil filter.
  4. Jul 15, 2021 at 7:30 AM
    eon_blue
    Azusa, CA
    Although in that case, those tunes would've been making people fail smog all along so I dunno
    Running Board Man likes this.
  5. Jul 15, 2021 at 7:31 AM
    Speedytech7
    Exactly, even the extremely devious tune my BMW had wouldn't have been detectable without the BMW OEM tools. To a regular OBD scanner it would appear ready because I told the ECU it never came with a catalyst monitor system at all rather than just disabling it checking... two ways to skin a cat but one looks legit afterward.
  6. Jul 15, 2021 at 7:31 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I have a fly in the left side headlight on the LX470. It came with the truck when I bought it. How it got in there I'll never know. I will need to pull the headlight to vacuum it out through the bulb socket opening. I'm thinking about leaving it there for good luck. Ha!
  7. Jul 15, 2021 at 7:34 AM
    eon_blue
    Azusa, CA
    Makes sense, no reason to worry about my 7th piggyback then other than the usual making sure it's hidden from view
  8. Jul 15, 2021 at 7:34 AM
    Speedytech7
    Yeah they can't see anything there, as long as it isn't trapping the ECU in open loop during testing.
  9. Jul 15, 2021 at 7:34 AM
    Running Board Man
    Running Board Man Well-Known Member
    There was a mosquito in my 95 Tacoma's guage cluster since 97 that I took out after flooding it
    04Pre_Runner and CS_AR[QUOTED] like this.
  10. Jul 15, 2021 at 7:36 AM
    Running Board Man
    Wouldn't that be detrimental anyway
  11. Jul 15, 2021 at 7:38 AM
    Speedytech7
    Eh, the 7th isn't exactly cutting edge equip. It can make its changes most effectively when the ECU isn't trying to tune around it, so it kicks the ECU into open loop when it wants to take over fueling and spark command because the ECU is no longer concerned with trimming at that point and the 7th's changes will be reflected more accurately. It's not a dynamic tuning device, it cannot adjust its map on the fly so it has to ensure conditions aren't changing around it to work properly.
  12. Jul 15, 2021 at 7:47 AM
    Running Board Man
    I never understood piggybacks till right this moment
  13. Jul 15, 2021 at 7:48 AM
    Running Board Man
  14. Jul 15, 2021 at 7:49 AM
    CS_AR
    LOL. I know.. LOL.
    I'm getting it installed at LR 4x4 Mud Connection. They are one of the very few places that I trust to do anything with a cruiser. The owners and guys that work there are all 80 and 100 series people. They come out and off-road with us. I'm getting to be buds with them.
    The owner has a drop dead gorgeous 80 series VX Diesel (left hand drive) and an equally nice 100 series. They are also going to align and most the SPC caster adjustment forward 1 notch and align it.
    They are great for doing the nit picky detailed stuff that burns up so much much my time. The only problem is they are 45 miles away.
    https://www.mudconnectionlr.com/gallery
    There is another place in Little Rock named The Cruiser Company.
    They do mostly frame off FJ40-FJ60 frame off "full tilt" restorations. Beautiful work but way way above my pay grade.
    http://www.cruiserco.com/
    http://www.cruiserco.com/Sam Houston.htm
    Abeyancer[QUOTED] likes this.
  15. Jul 15, 2021 at 7:51 AM
    Speedytech7
    That's an oversimplification but certainly takes away some of the magic people think it does
  16. Jul 15, 2021 at 7:56 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  17. Jul 15, 2021 at 7:58 AM
    Speedytech7
    CS_AR likes this.
  18. Jul 15, 2021 at 7:59 AM
    JKO1998
    Utah
    The price is funny
    I should probably drop my camper right with the market
  19. Jul 15, 2021 at 8:00 AM
    Speedytech7
    I'd drop it right off the edge of a cliff
    Kwikvette and Running Board Man like this.
  20. Jul 15, 2021 at 8:00 AM
    JKO1998
    Utah
    If that’s what the buyer wants
