  1. Aug 22, 2021 at 9:04 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I get it,
    sets 4:30 am alarms*
  2. Aug 22, 2021 at 9:41 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    So if you're just gonna replace the seals it'll be a lot easier (thats usually what goes bad in the first place) I rebuilt my entire rack on my Supra and it was pretty easy. The Tacoma's is similar but the control vavle looks to be a little bit more in depth than the Supras.
    https://www.tacomaworld.com/threads/rack-pinion-service-tools-tips.312600/
  3. Aug 23, 2021 at 4:50 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    What type of saws do you guys use in the woods? I have some band saws and an Echo gas-operated chainsaw. Nowadays, I guess people are using rechargeable electrics.
    I see the Milwaukee M16-M16 models. Nice. Though this might be used once a year at the most.
    Taco critter likes this.
  4. Aug 23, 2021 at 6:20 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Stihl MS
    Abeyancer and CS_AR like this.
  5. Aug 23, 2021 at 6:48 AM
    JKO1998
    Utah
    Why would a power steering pump die for 3 days and then randomly kick back on?
    air bubble?
  6. Aug 23, 2021 at 7:09 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Internal hose degrading
    CS_AR likes this.
  7. Aug 23, 2021 at 7:25 AM
    JKO1998
    Utah
    In the pump?
  8. Aug 23, 2021 at 7:42 AM
    JKO1998
    Utah
  9. Aug 23, 2021 at 7:44 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    04Pre_Runner likes this.
  10. Aug 23, 2021 at 7:46 AM
    Empty_Lord
    Dan
    Mcculloch sp82. Overkill
  11. Aug 23, 2021 at 7:47 AM
    JKO1998
    Utah
    all of these are your own fault hah
    Empty_Lord[QUOTED] and Kwikvette like this.
  12. Aug 23, 2021 at 7:49 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  13. Aug 23, 2021 at 8:00 AM
    Wulf
    rock raisin
    is the belt tight?
    if the pump is working and there's air in the system it will whine a bunch and also puke fluid when the engine gets shut off. You sure it's the pump and not the rack?
  14. Aug 23, 2021 at 8:03 AM
    JKO1998
    Utah
    I looked in the reservoir and the fluid wasn’t moving, is now.
    It did burp one time
    Wulf[QUOTED] likes this.
  15. Aug 23, 2021 at 8:10 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    And all those will be towed to the junkyard by his grandkids after his estate is settled.
    Running Board Man and Kwikvette like this.
  16. Aug 23, 2021 at 8:18 AM
    Speedytech7
    Not one of them having ever run during his term of ownership either
  17. Aug 23, 2021 at 8:26 AM
    Wulf
    rock raisin
    Check the belt tightness and all of your return hoses to see if any of them look collapsed
    JKO1998[QUOTED] likes this.
  18. Aug 23, 2021 at 8:47 AM
    Empty_Lord
    Dan
    Indeed
  19. Aug 23, 2021 at 8:54 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Notice that there is indeed pineapple on that pizza.
  20. Aug 23, 2021 at 8:55 AM
    Speedytech7
    I'm choosing to believe that it's chunks of white onion rather than a sadistic hot circle of garbage
    Kwikvette likes this.
