  1. Aug 24, 2021 at 6:24 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    How long before it’s red orange and yellow
    Das it mang and Taco critter like this.
  2. Aug 24, 2021 at 6:28 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Unless I'm buying a NSX I'll only buy 4 cyl Hondas. I hate transverse mounted engines. A v6 crammed in the engine bay is bad enough longitudinal.
  3. Aug 24, 2021 at 6:59 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    The V6ers had oil leak problems. Rear main seal and some other strangely placed oil seal that I can't remember the name. Changing the right bank O2 sensor was a pain as I recall. The rear main oil seals lasted 60,000 miles then they started leaking like crazy. A replacement seal would last another 60,000 miles and need to be replaced.
    California in their goodness won a class-action lawsuit against Honda that made them fix it or awarded the owner something like $1,000 or $1,200 to get it fixed.
    The only transverse-mounted V6 that I enjoy working on is a VQ30. I truly enjoy working on those engines like I do a 5VZ.
    Though they don't require much maintenance and I haven't really needed to work on one since I started working with Toyotas.
    Too bad those days belong to the past.
  4. Aug 24, 2021 at 7:10 AM
    CS_AR
  5. Aug 24, 2021 at 7:14 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    im kind of amazed how little I’ve had to do to my vq40. Last time I had the cover off was to change the plugs 60,000 miles ago. It doesn’t even smell oily under the hood.
    having grown up around 90s chevys, this is kind of mind blowing :laughing:
    CS_AR[QUOTED] likes this.
  6. Aug 24, 2021 at 7:33 AM
    Wulf
    rock raisin
    Yea a honkytonk dive
    Is where I'd rather be
    Cause theres a bar stool
    Waitin right there for me
    Taco critter likes this.
  7. Aug 24, 2021 at 7:36 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The first V6 I worked on regularly too. Don't really miss the dumb injectors though.
  8. Aug 24, 2021 at 7:45 AM
    CS_AR
    The Toyotas we have are more reliable without the side feed o-ring and plastic pintle caps. I actually published a tutorial on how to refurbish those side feeders.. A few people did it. I have a set running that I refurbished roughly 10 years ago. I should give them a refresh to since it has been so long. I should have the kits in stock.
  9. Aug 24, 2021 at 7:53 AM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    Any thoughts on the vr30ddtt?
  10. Aug 24, 2021 at 8:10 AM
    Wulf
    rock raisin
  11. Aug 24, 2021 at 9:08 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  12. Aug 24, 2021 at 9:10 AM
    JKO1998
    Utah
    You stop right now
  13. Aug 24, 2021 at 9:38 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  14. Aug 24, 2021 at 9:40 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
  15. Aug 24, 2021 at 9:50 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Das it mang[QUOTED] likes this.
  16. Aug 24, 2021 at 9:52 AM
    Das it mang
    Az
    1996 T100 SR5 MT
  17. Aug 24, 2021 at 9:53 AM
    CS_AR
    I would talk to Moncef at Admin Tuning. It's an R-spec Skyline engine. Not new. Should be proven. Would be fun to take one out.
    https://youtu.be/n3XsKB_UzNU
  18. Aug 24, 2021 at 9:53 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Kwikvette[QUOTED] likes this.
  19. Aug 24, 2021 at 9:54 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Yes officer, this post right here.
  20. Aug 24, 2021 at 9:54 AM
    Wulf
    rock raisin
