  1. Sep 10, 2021 at 8:24 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I think I remember @eon_blue and @Kwikvette replacing seals recently.
    Kwikvette likes this.
  2. Sep 10, 2021 at 8:24 PM
    eon_blue
    Azusa, CA
    Yeah neither of us have had great luck at doing it either lol.
    CS_AR[QUOTED] and Kwikvette like this.
  3. Sep 10, 2021 at 8:26 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    If you were to make 1 post a week for now on, it’d take you 1000 years to double your post count
    plus or minus 6
  4. Sep 10, 2021 at 8:26 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I need to put the stereo back in the Nissan so I can just tear apart the whole front end on the Toyota
    BartMaster1234 likes this.
  5. Sep 10, 2021 at 8:30 PM
    eon_blue
    Azusa, CA
  6. Sep 10, 2021 at 8:30 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I have to do the same for my z, lol. I am adamantly against putting any kind of aftermarket stereo in this thing, the stock one is such an 80’s vibe it’ll ruin the aesthetic if I put a new one.
    I have to replace all the caps and stuff, it barely works and sounds like a washed out bathtub. I’ll probably solder an aux to the cassette points on the circuit board.
    What nissan do you have?
  7. Sep 10, 2021 at 8:32 PM
    0xDEADBEEF
    Yeah that’s too cool to replace with modern crap. Caps are at least easy to source too.
    Just a 2007 frontier, owned it since 2008.
  8. Sep 10, 2021 at 8:37 PM
    JKO1998
    Utah
    They make a cassette aux cord
    Arsvita Car Audio Cassette to Aux Adapter , 3.5 MM Auxillary Cable Tape Adapter https://www.amazon.com/dp/B07N2KPTGW?_encoding=UTF8
  9. Sep 10, 2021 at 8:55 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah...passenger one leaked for some 2 months or so and I finally decided to tackle it -
    I haven't pulled the skid to see where my leak is coming from but I'm sure it's puking from around the seal again :violent:
    :anonymous:
  10. Sep 10, 2021 at 8:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I had the urge a few nights ago to watch this show all over again...
    eon_blue[QUOTED] likes this.
  11. Sep 10, 2021 at 8:57 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    04Pre_Runner likes this.
  12. Sep 10, 2021 at 9:02 PM
    Wulf
    rock raisin
    I think one time I did the diff seal I had to replace it 2 additional times before it stopped leaking. Between cheap seals and installer error it was a sinking ship
  13. Sep 10, 2021 at 9:02 PM
    Wulf
    rock raisin
  14. Sep 10, 2021 at 9:02 PM
    Wulf
    rock raisin
    eon_blue likes this.
  15. Sep 10, 2021 at 9:04 PM
    Wulf
    rock raisin
  16. Sep 10, 2021 at 9:17 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    This 01 4Runner isn't going to be fun. Had to dig the brake bleeder screw out of like an inch of mud/gear oil. I've determined it's likely not the brakes causing the shaking when braking. Only happens at high speed and when the suspension is loaded up.
    Also pulled the ebrake at highway speeds. And while it barely slowed me down due to the blown axle seals, I didn't feel any shaking at all. When braking at lower speeds that don't load the suspension up I don't get the shaking. I've felt all the suspension and nothing is crazy loose but everything is blown out. Original suspension with 180K of mostly city/ranch miles. Lower shock bushings are gone, lower ball joints have some play, tie rods are gone.
  17. Sep 10, 2021 at 9:19 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    "Do it yourself" they said. "It's easy and you'll learn stuff" they said.
    Mine's still peacefully seeping away.
  18. Sep 10, 2021 at 9:43 PM
    Wulf
    rock raisin
    You learn a lot about your personal limits
  19. Sep 10, 2021 at 10:03 PM
    Wulf
    rock raisin
    I started to change out the shocks on the Ford and decided I should be fixing the house first
  20. Sep 10, 2021 at 10:05 PM
    Wulf
    rock raisin
