  1. Sep 10, 2021 at 10:12 PM
    Wulf
    rock raisin
  2. Sep 10, 2021 at 10:13 PM
    Wulf
    rock raisin
  3. Sep 10, 2021 at 10:16 PM
    Wulf
    rock raisin
  4. Sep 10, 2021 at 10:42 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    That's all good, do you still have the brackets I gave you?
  5. Sep 10, 2021 at 10:42 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Yup I've got the C bracket, two straight brackets, shocks, and everything in the pic.
  6. Sep 10, 2021 at 10:48 PM
    Tour991
    James
    South Reno/Tahoe
    You are good to go, call me if you need help instaling it tomorrow
  7. Sep 10, 2021 at 11:06 PM
    eon_blue
    Azusa, CA
    The first few seasons are some of the best TV ever made. Starts going downhill after season 5, and don't get me started on the last season.
    They really should redo it all from season 5 onward but that'll never happen lol.
    Kwikvette[QUOTED] likes this.
  8. Sep 10, 2021 at 11:12 PM
    eon_blue
    Azusa, CA
    Speaking of great shows that failed toward the end, they're making a new final season of Dexter to make up for the catastrophe that was the finale of that one. Though I think that show was only really good for the first two seasons, the rest were meh. The trailer for the new one looks promising though.
    CS_AR likes this.
  9. Sep 11, 2021 at 6:26 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Here are a few shots of mine for reference. Per the Amazon spec page, my cylinders measure 35.43" x 2". If you lengths are different, you may need to do a ratio of my measurements if you don't already know your mounting points.
    from the rear, 8" from the outside lip to the center of the mounting ball
    Rear edge of lower bracket to the tailgate
    As you can see, mine were riveted by PO. Seem to be holding just fine.
    These dampers work really well. It takes more effort to lower the top than to raise it.
    BartMaster1234[QUOTED] and CS_AR like this.
  10. Sep 11, 2021 at 6:56 AM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    Nobody lined up, but I'm not in a big rush.
    eon_blue[QUOTED] likes this.
  11. Sep 11, 2021 at 7:27 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Kwikvette, CS_AR and Das it mang like this.
  12. Sep 11, 2021 at 7:54 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    morning morning, working per usual but happy to be busy
    Kwikvette, CS_AR and 0xDEADBEEF like this.
  13. Sep 11, 2021 at 8:04 AM
    0xDEADBEEF
    Gave the drivers steering boot a good squeeze and got a bunch of fluid.....and a bunch of water. I suspect that shaft is all rusted and causing the seals to leak. No wonder they've got it all clamped tight, once you get a hole water gets in but it doesn't get out.
    Good news is it only seems to happen when its at the extreme ends of travel so its not squirting when i'm running down the highway.
    Das it mang likes this.
  14. Sep 11, 2021 at 8:34 AM
    0xDEADBEEF
  15. Sep 11, 2021 at 8:36 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    @Empty_Lord
    when I push the break it sounds like a puff of air being released into the cab, I though it was just the boot on the back side of the booster but now I’m thinking maybe it’s something worse, thoughts?
  16. Sep 11, 2021 at 9:03 AM
    eon_blue
    Azusa, CA
  17. Sep 11, 2021 at 9:35 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    That's the exact guide I used, his special Ocho-socket he created, I crudely duplicated with a 1" shaft collar that I picked up from Ace Hardware. I then took a flap disk to the edges till I was fairly close to fitting
    I can't tell you if it worked or not because it's still waiting to get installed in the truck when I do all my other work :laughing:
    0xDEADBEEF[QUOTED] likes this.
  18. Sep 11, 2021 at 9:40 AM
    Wulf
    rock raisin
    Hmmm
  19. Sep 11, 2021 at 9:42 AM
    0xDEADBEEF
    If it works it works! Probably!
    I don't have any kind of press here, which seems to be kind of a key item. At least if you want to do it smoothly.
    And time is in short supply these days.
    Abeyancer[QUOTED] likes this.
  20. Sep 11, 2021 at 9:44 AM
    0xDEADBEEF
    We can fix that. Meet the the eCocaine App! Brought to you by the fine people behind Candy Crush! Share your favorite lines with friends and family, log your uses, calculate your optimum dose, and find the nearest dealer!
    Coming soon - Integration with DoorDash!
    Abeyancer and eon_blue[QUOTED] like this.
