  1. Sep 13, 2021 at 12:38 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Should be fine. Just don’t top off
    slander[QUOTED] likes this.
  2. Sep 13, 2021 at 12:38 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Ahhh ok. I wonder if it was different on 01 up
  3. Sep 13, 2021 at 12:40 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Ok cool, I should be able to actually fuel it right? Reading a description of what it does now and that's what I'm not 100% sure on.
    EDIT: I see there is another valve that will allow air into the tank via the charcoal canister so Ill be good, at least I assume.
    Its also called the overfill or rollover valve, so I'm sure your truck has it.
  4. Sep 13, 2021 at 12:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Mine looks like the Vans logo :burp:
    Should see the many signatures by customers over the years; some write like they're god damn 5 years old, others swear they're doctors...
    se7enine[QUOTED] likes this.
  5. Sep 13, 2021 at 12:42 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    My names written different everytime I write it
    eon_blue[QUOTED] likes this.
  6. Sep 13, 2021 at 12:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It'll matter when you buy a house; shit better match.
    That and don't go adding an initial in all your signatures only to omit it in one, cause then you'll have to sign all over again.
    Same with private property in CA.
  7. Sep 13, 2021 at 12:46 PM
    Running Board Man
    Running Board Man Well-Known Member
    What do you know about 5sfes?
    The one in my 96 is from 93 according to the vin tag on it and has big cams
    I got a rebuilt head with cams for a "5sfe" that went on fine but a couple bolt locations and small things are different but the cams are weak compared to the old ones that came out
    Would you be able to find out what it came off of if I gave you some casting marks or something along those lines?
    I'm wondering if I can use the big old cams in the new head If I just transfered the lifters over to the new head... I just don't want to not be able to cruise at 90 like I was before since I would be running smaller cams now I was getting 31mpg on the bigger ones anyway
    Das it mang likes this.
  8. Sep 13, 2021 at 12:47 PM
    JKO1998
    Utah
    Haha
    buy a house
    What do you think I am? A millennial??
  9. Sep 13, 2021 at 12:47 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That my local junkyard is chock full of em
  10. Sep 13, 2021 at 12:50 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  11. Sep 13, 2021 at 12:53 PM
    0xDEADBEEF
    looks like it’s different, rockauto lists completely different filler neck parts . The newer one has an extra hose on it.
    Something I’ll have to look into more for the next version of my flatbed filler
  12. Sep 13, 2021 at 12:54 PM
    slander
    Hickory, NC
    So glad I switched over to a quick squiggle, saved me hours buying two houses.
    Kwikvette[QUOTED] likes this.
  13. Sep 13, 2021 at 12:56 PM
    eon_blue
    Azusa, CA
    Lawn Crawler status unlocked
  14. Sep 13, 2021 at 12:57 PM
    Running Board Man
    IMG_20210913_145551161.jpgbig old vs small new
  15. Sep 13, 2021 at 12:57 PM
    slander
    Hickory, NC
    Interesting
  16. Sep 13, 2021 at 12:58 PM
    Speedytech7
    That's a very large cam profile difference for a shim over bucket engine
  17. Sep 13, 2021 at 12:59 PM
    Running Board Man
    Yeah... On the test drive I was like, shit I'm doing 90 and it's still pulling
  18. Sep 13, 2021 at 1:11 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    and that bitch ran with the stock ECU?
  19. Sep 13, 2021 at 1:14 PM
    Wulf
    rock raisin
    sounds like it was a pretty good first day. Were you excited?
  20. Sep 13, 2021 at 1:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Not only that, he did burn outs in the Papa Johns parking lot :burp:
