  1. Sep 14, 2021 at 9:13 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I was surprised, it’s 10 minutes from my house. Lots of wildlife, even saw 2 bald eagles.
    Das it mang likes this.
  2. Sep 14, 2021 at 9:16 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    any of them pandaroos of the garbage sort tho?
  3. Sep 14, 2021 at 9:16 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Gotdangit :pout:20210914_091430.jpg
    Think I should put in the sales brochure "artisanally made equipment":laughing:
    Kwikvette and 0xDEADBEEF like this.
  4. Sep 14, 2021 at 9:17 AM
    Wulf
    rock raisin
    @eon_blue will fix it in post processing
    Abeyancer[QUOTED] likes this.
  5. Sep 14, 2021 at 9:19 AM
    0xDEADBEEF
    Nah, they were all busy at a fundraiser.
    Das it mang[QUOTED] likes this.
  6. Sep 14, 2021 at 9:19 AM
    Wulf
    rock raisin
    I've started to get more and more particular about that. I don't like it anywhere and try to keep it out of the house as much as possible
  7. Sep 14, 2021 at 9:21 AM
    0xDEADBEEF
    I keep getting stabbed in the foot by tiny pieces of steel. All safe in the garage with boots, but apparently it just sticks to everything and travels.
  8. Sep 14, 2021 at 9:21 AM
    Abeyancer
    Jimmie
    PNW
    I like your thinking
  9. Sep 14, 2021 at 9:24 AM
    eon_blue
    Azusa, CA
    Fix what now
  10. Sep 14, 2021 at 9:27 AM
    Running Board Man
    Running Board Man Well-Known Member
    How did you simultaneously get that hot but also not make a big ass hole
  11. Sep 14, 2021 at 9:28 AM
    Running Board Man
    My bath tub is permanently stained from that shit from washinh my hair after welding school
  12. Sep 14, 2021 at 9:28 AM
    Abeyancer
    Jimmie
    PNW
    The cages are supposed to the same distance away from the frame lol
  13. Sep 14, 2021 at 9:28 AM
    Wulf
    rock raisin
    Kwikvette likes this.
  14. Sep 14, 2021 at 9:28 AM
    Wulf
    rock raisin
    magic eraser and CLR
  15. Sep 14, 2021 at 9:29 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    I just scrubbed mine yesterday to get off the undercoating spray that was stuck on my hands then stuck to the tub. GF wasn't happy with it lmao
  16. Sep 14, 2021 at 9:29 AM
    Abeyancer
    Jimmie
    PNW
    Magic?:notsure:
    I think it's because I wasn't moving my puddle fast enough all the heat transfered to the pipe but the volts were set low enough it didn't burn through
  17. Sep 14, 2021 at 9:31 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Anything you grind with a carbide burr or an endmill makes little knives from hell that are sharp enough to instantly embed in anything.
    0xDEADBEEF[QUOTED] and Wulf like this.
  18. Sep 14, 2021 at 9:32 AM
    Wulf
    rock raisin
    oh god the endmill nooo
    I still find aluminum shreds from the last project despite multiple cleanings since
    Running Board Man likes this.
  19. Sep 14, 2021 at 9:34 AM
    0xDEADBEEF
    That explains it, I get a ton of use out of the carbide bits on my die grinder.
    Yall have any luck with those magnetic pickup things with wheels ? Or is a regular push broom good enough?
  20. Sep 14, 2021 at 9:34 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    so, i watched a vid on how to do trans fluid change this morning. let me know if i got it correctly, need to do it in coming weeks: 3 quarts of 75 w 90 gl4, drain and fill bolts are both 24 mm on the housing, drain and refill just like the rear diff, let it overflow? That's it? That easy?
    Edit: Oh and ill need to change the washers while im at it right? been reusing the oil pan washer, but no leaks
