  1. Sep 15, 2021 at 2:45 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I haven't dropped it on the 4R, but did twice on the Prerunner.
    Jacked from the front cross member, with stands on the frame.
    Didn't have to mess with steering rack bolts myself as I've read some people do and others don't.
    treyus30[QUOTED] likes this.
  2. Sep 15, 2021 at 2:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Some people only use their phone on this site, and never in landscape :burp:
    I forget who it was that only recently learned about sigs lol
    04Pre_Runner likes this.
  3. Sep 15, 2021 at 2:54 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Completely forgot about that.
  4. Sep 15, 2021 at 2:55 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I never knew sigs went away in portrait mode actually; I always used this site on my work PC.
  5. Sep 15, 2021 at 2:58 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    So once it's jacked and the alignment bolts are out, you should be able to just swing it down right?
    Can you do it without taking the wheels off?
  6. Sep 15, 2021 at 3:00 PM
    Tour991
    James
    South Reno/Tahoe
    You have a lot of little projects to get done on that. I get the don't wannas, I need to finish the rear on the 97 and I need to do all the front joints on the 4runner. Plus I go back to work Monday and Monica goes back to school. Hope the 4runner front end holds together for another 2 weeks.
  7. Sep 15, 2021 at 3:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I had the wheels off, remember undoing the bolts, but also undid the LBJ as I replaced the LBJ's that day.
  8. Sep 15, 2021 at 3:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Das it mang likes this.
  9. Sep 15, 2021 at 3:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Another project to add is, installing all the black interior trim parts.
    Just before I vacated the apartment I thought "oh, I'll quickly swap the parts over"
    Pulled a window switch real quick which takes 2 seconds, only to see that the switch connector is completely different. The pinout varied slightly, but had the same number of pins.
    Really, I could just undo the "trim" from the switch itself but without a flathead screw driver and other little tools, I didn't want to risk breaking any tabs.
    Surprised that even though both models use the same switches IE window up/down and mirror adjustment, and they're both the same year, the plug style differs between my Limited and the SR5 it came from.
    You should be able to get the front end together real quick for Monica!
    Hard part is waiting for parts to arrive.
    What all does the 4R need anyway?
  10. Sep 15, 2021 at 3:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    CS_AR likes this.
  11. Sep 15, 2021 at 3:15 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Meeeeeeee
    Kwikvette[QUOTED] and Tour991 like this.
  12. Sep 15, 2021 at 3:21 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Don't forget that the LCA is under compression from the front springs.
  13. Sep 15, 2021 at 3:22 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I had to unbolt the steering rack to get the bolts out
  14. Sep 15, 2021 at 3:26 PM
    Tour991
    James
    South Reno/Tahoe
    I ran into the same issue when I swapped out the mirrors. The white 4runner mirrors had a different conector then then the black 4runner mirrors. Not sure if they are the same year. I just made some jumper wires to fix the problem.
    The front end other than the torn cv boot does not look bad but I did get some vibration when breaking at 55mph and not knowing how long any of the joints have been on it I would rather just replace it.
    I will be driving it till I change it out. I'd rather it brake on me then on her.
    Kwikvette[QUOTED] likes this.
  15. Sep 15, 2021 at 3:48 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Right, so I'm wondering if jacking it up will relieve enough tension to just pull it down but keep it relatively in place
  16. Sep 15, 2021 at 3:50 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Anyone run the TYC "Cali style" mirrors?
  17. Sep 15, 2021 at 3:54 PM
    JKO1998
    Utah
    Why wouldn’t you just take the LCA off? Much easier
    Kwikvette likes this.
  18. Sep 15, 2021 at 3:55 PM
    eon_blue
    Azusa, CA
    I don't either
    and now I've got a fucking u-joint to do as well
    and the LCA at some point before our trip
  19. Sep 15, 2021 at 3:55 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Essentially what I was going to say.
  20. Sep 15, 2021 at 3:55 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Wait what
