  1. Sep 15, 2021 at 7:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No dealership that I know of out here owns their own gas station. Not saying it isn't a thing, hell that'd be cool.
    For gas, we always had a Chevron account with a card that gets paid every month; Shell for diesel.
    It's hugely convenient for a dealership to have such an agreement with a nearby gas station (fuel is cheaper than advertised), and the gas station has continued business.
  2. Sep 15, 2021 at 7:29 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just me, my PC is in storage until our house is built.
    Got a new laptop; it can game but not the same way.
  3. Sep 15, 2021 at 7:30 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I’d be down for some GTA shit one night if @xtremewlr has it
  4. Sep 15, 2021 at 7:32 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    So it takes the place of the transfer case and does lower gears?
    I wonder how strong it actually is...what's the weak point on the stock 4x4 transmissions?
  5. Sep 15, 2021 at 7:32 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Steak strips tn, bout to cook the potatoes
    Edit:
    Kwikvette likes this.
  6. Sep 15, 2021 at 7:35 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I don’t know how it works. Pretty sure you use it and the stock case.
    The combination let’s you get into a really low gear ratio (maybe it’s big idk), letting your truck crawl over stuff with our really using the throttle.
    but that could all be wrong, Someone that actually know s may chime in.
  7. Sep 15, 2021 at 8:03 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sorry, my last post was harsher than I wanted it to be, partially thanks to speech to text. My thought would be to solid axle swap your truck if you insist on having 4WD. But, and this is the tough love portion, the 5 lugs put you in the worst place to start that adventure. Your fenders are narrower, you have no transfer case or a trans that will work here, your frame actually drops down even lower than a 6 lug so you'd need to hack off not only the IFS mounts but also the frame itself and rebuild it with clearance for your solid axle, and you'd also need to source a more stout rear axle. This is just for a basic bitch leaf spring SAS too, and frankly you can do better than that for travel and comfort IMHO. Now here's the upside, they make pretty bomb IFS long travel kits for 5 lugs, like serious travel. You just have to be okay with no 4WD, which in the desert is doable, just don't wheel alone in unfamiliar territory and you can have tons of fun with a LT 5 lug. @MadTaco461 has a wicked 5 lug LT build, that I would copy to a tee if I found myself with one.
  8. Sep 15, 2021 at 8:11 PM
    Running Board Man
    Running Board Man Well-Known Member
    Depends how you have the tq wrench on the deal but I'd see in most scenarios you add torque
  9. Sep 15, 2021 at 8:13 PM
    Running Board Man
    Same here
  10. Sep 15, 2021 at 8:19 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Looks familiar.
  11. Sep 15, 2021 at 8:26 PM
    CS_AR
    I had forgotten about these. This should be mounted on top of a Dodge Ram 4x4 with some big ass tires.
  12. Sep 15, 2021 at 8:28 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Mkay. Cuz I need to get the stuff for 4x4 conversion at some point and I've been interested in crawler boxes as well
  13. Sep 15, 2021 at 8:29 PM
    JKO1998
    Utah
    I’d worry about the 4x4 thing first
    And then decide what you really need after that
    04Pre_Runner likes this.
  14. Sep 15, 2021 at 8:30 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Why convert twice though ya know? If its a direct transfer case replacement, I could just get that instead of a take-off
  15. Sep 15, 2021 at 8:31 PM
    JKO1998
    Utah
    I don’t think it works like that
  16. Sep 15, 2021 at 8:33 PM
    Speedytech7
    I think that one you posted does actually, its a gear drive conversion case, it just doesn't let you choose low ratios, you get 4.7 or hi range
    04Pre_Runner and treyus30 like this.
  17. Sep 15, 2021 at 8:35 PM
    JKO1998
    Utah
    It does say drop in replacement in the description :anonymous:
  18. Sep 15, 2021 at 9:24 PM
    CS_AR
    I think its still illegal to pump your own gas in New Jersey. Must be a license requirement.
  19. Sep 15, 2021 at 9:26 PM
    CS_AR
    Did you tip the attendant?
  20. Sep 15, 2021 at 9:26 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    No she saw me filling up myself and walked away haha.
    treyus30 and CS_AR[QUOTED] like this.
