  1. Sep 21, 2021 at 9:12 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Lube is cheap insurance since Taco is on lift anyway. 15k is adequate also.
    60k is asking for catastrophic failure.
    My $.02
    Running Board Man likes this.
  2. Sep 21, 2021 at 9:17 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    I'm at almost 50k miles on the truck since i bought it, and i havent done it once, wish me luck
  3. Sep 21, 2021 at 9:17 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    will update, thank you
  4. Sep 21, 2021 at 9:36 AM
    eon_blue
    Azusa, CA
    I do mine about once a year as well, most times I do it I can put one pump in each zerk and you can see the old grease getting pushed out. The old stuff is definitely still in there
    Makes a bloody mess too when the driveshaft flings it around
  5. Sep 21, 2021 at 9:44 AM
    eon_blue
    Azusa, CA
    check the carrier bearing. The bushing around it tends to crack and deform over age/miles. In all that dry heat I wouldn't be surprised if it's starting to go or already has. Easy replacement to do
    At least I assume 5 lugs have CBs...I think just the reg cabs don't have them.
  6. Sep 21, 2021 at 9:57 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Rust preventative
    eon_blue[QUOTED] likes this.
  7. Sep 21, 2021 at 10:13 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  8. Sep 21, 2021 at 11:09 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    At home, open book tests have got to be the stupidest thing ever, unless youre the student.
    Make homework worth more
    Kwikvette and Speedytech7[OP] like this.
  9. Sep 21, 2021 at 11:11 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    One of my favorite professors had homework worth 60% and tests worth 20%, the other little bit was projects. You learn the most from homework if you do it regularly and you do it regularly if its worth something.
    Kwikvette likes this.
  10. Sep 21, 2021 at 11:21 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    It's upside down.
    eon_blue likes this.
  11. Sep 21, 2021 at 11:24 AM
    JKO1998
    Utah
    I don’t have exams in 2 of my classes this semester. One is just a group project due at the end, the other one is homework and labs.
    it’s niiice
  12. Sep 21, 2021 at 11:36 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    What about 275k :anonymous:
    I replaced them, but they still worked ;)
  13. Sep 21, 2021 at 11:38 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I think I finally came up with a name for the 100 series so now I can do a build thread. Sloopy.
  14. Sep 21, 2021 at 11:39 AM
    Speedytech7
  15. Sep 21, 2021 at 12:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Interesting stuff, cutting today that is.
    CS_AR, Das it mang and 04Pre_Runner like this.
  16. Sep 21, 2021 at 12:15 PM
    Wulf
    Wulf no brain just damage
    rock raisin
  17. Sep 21, 2021 at 12:25 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    it's not a phase?
    Kwikvette[QUOTED] likes this.
  18. Sep 21, 2021 at 12:33 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Cutting through thin metal was quick and easy.
    Cutting through thin metal double stacked with tiny gap in between was not so easy :rofl:
    In a situation like this, you wouldn't use oxy-fuel as you can just cut through it with a wheel. The reason why this was a little difficult at first was because the top layer wants to melt before the bottom layer cuts.
    After figuring out how quickly the top layer melts I was able to cut the rest with ease.
    I was given some pieces to cut through some welds. Being told that the welds themselves are stronger than the base metal, I kind of figured I would just need to sit on it a little bit longer.
    Cut it easily.
    Then I was given monstrosity, and told to cut it up and destroy it.
    Didn't get a before picture but you get the idea.
    That's also where I got the heart from, but it was before I cut the cubicle and half.
  19. Sep 21, 2021 at 1:47 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    This might be a weird question, but does anyone know if there's an aftermarket steel bumper (could be weldable) that emulates the volume behind the OEM bumper near the bottom center?
    That's where my intercooler is and I don't want to move it, but I kinda want a winch at some point.
  20. Sep 21, 2021 at 1:48 PM
    Wulf
    rock raisin
    DIY
