  1. Sep 23, 2021 at 9:49 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    caved and scheduled an appointment for a rotate/rebalance for the Ford tomorrow.
    The front end is in OK shape as far as I can tell and it drives great 99 pct of the time... but I hit a bridge joist at 80 yesterday and got the death wobble.
    front tires are kind of fucked up from lack of rotations and the bad old shocks, hopefully it's just that and I can get by with the rotation/rebalance til I finish moving. I have another set of tires in storage :homer:
    Speedytech7[OP] likes this.
  2. Sep 23, 2021 at 9:50 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The cruiser has occassionally started doing this when turning left above 65mph. I'm starting to think I should get all the new bushings pressed in now.
  3. Sep 23, 2021 at 9:52 AM
    Wulf
    rock raisin
    hey, I'm having a similar problem, it is very likely to happen if I hit a bridge joist or pothole while turning left above 60 MPH.
    New track bar bushing/ball joint, new bilstein steering stabilizer, ball joints seemed tight when I checked with the 4 foot pry bar. Tie rod ends are meh in my opinion but the shop said they were fine.
  4. Sep 23, 2021 at 9:52 AM
    Running Board Man
    Running Board Man Well-Known Member
    I never got the chance to test drive a 4.0 6 speed or is it 5speed
    They 3.4 has a 5 speed or auto
    The v8s were only automatics
    Das it mang[QUOTED] likes this.
  5. Sep 23, 2021 at 9:53 AM
    Running Board Man
    I honestly was finding more 4.0 and 3.4 tundras vs 4.7
    I found 2 4.0 manuals that I never got to test drive
    Das it mang likes this.
  6. Sep 23, 2021 at 9:54 AM
    Speedytech7
    I'm due for TREs and panhard bushings, so I'll start there. But the radius arms likely need bushings too and I need to install my new lower links for the rear.
    Wulf[QUOTED] and Das it mang like this.
  7. Sep 23, 2021 at 9:54 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    they come in 4x4? p sure ur right the 4.0 was 6 speed.
  8. Sep 23, 2021 at 9:54 AM
    eon_blue
    Azusa, CA
    4.0 2nd gens have 6 speed manuals, 5 speeds for the 2.7l
  9. Sep 23, 2021 at 9:55 AM
    Running Board Man
    Shit idk... maybe
    My neighbor has a 4.0 auto 2wd
    Definitely better than a 3.4 auto
  10. Sep 23, 2021 at 9:56 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    still doing some research to learn more on them. might replace the slug with one when the need for more cab space comes years down the road. the v8s require timing belt changes just like the v6s correct?
    Running Board Man likes this.
  11. Sep 23, 2021 at 9:57 AM
    Running Board Man
    Yes not it's not that big of a deal honestly
    Did one on my mom's 4.7 landcruiser and it wasn't bad
  12. Sep 23, 2021 at 9:58 AM
    Speedytech7
    I don't think the UR V8s do but the UZ V8s will, they're easy. I'd rather have timing belts these days, they maintain time better, less noisy, and make working on the front of the engine easier.
  13. Sep 23, 2021 at 9:58 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    thats reassuring, thanks for the knowledge. Do the 1st gen tundras have different lbj design to avoid the 6 lug flaws?
  14. Sep 23, 2021 at 9:59 AM
    Speedytech7
    nope haha, just as bad if not worse
  15. Sep 23, 2021 at 9:59 AM
    5amStevens
    5amStevens Well-Known Member
    Gilbert, Arizona
    2000 Tacoma 4x4 Prerunner TRD
  16. Sep 23, 2021 at 9:59 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    womp womp
  17. Sep 23, 2021 at 9:59 AM
    Running Board Man
    About that, their identical
    Till 2004 than the bolts got sized up to m10 and the ball joint got made bigger
    To me 100% of the lbj problems are user error, either over-torquing of the bolts, using cheap parts, or never checking for play till they fail
    There's 2 different bolts 1st gen tacomas and 3rd gen 4 runners came with, along with 2 different part numbers that got 2 different torque specs... Those who get or have the newer bolts and use the older spec have problems with them stretching/failing
    The 315k mile ball joints on my tundra have no play
  18. Sep 23, 2021 at 10:02 AM
    eon_blue
    Azusa, CA
    until you hit a curb doing donuts at Papa Johns
  19. Sep 23, 2021 at 10:03 AM
    Running Board Man
    Honestly... That's the story of every vehicle I get, no problems at time of purchase 2 months later "why's my wheel feel soo weird"
    -new upper/lower control arms, upper/lower ball joints, inner and outer tie rods, rack bushings later it returns to feeling right
  20. Sep 23, 2021 at 10:04 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    yeah i have no gripes about them, id definitely agree they dont just explode without warning. Looks like ill be considering a swapped dblcb 1st gen or 1st gen tundra when the time comes. Car market is dooky rn and ive got plans for the slug. thanks again for the info guys!
