  1. Sep 30, 2021 at 7:03 PM
    Running Board Man
    Running Board Man Well-Known Member
    U joint phasing is important
    04Pre_Runner and Wulf like this.
  2. Sep 30, 2021 at 7:07 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    You are taking the right precautions...
    Have you considered adopting a large animal as well?
  3. Sep 30, 2021 at 7:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Washing your balls is important.
    Abeyancer likes this.
  4. Sep 30, 2021 at 7:09 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Could also do Lexan if its in the shade
    Phasing with what?
  5. Sep 30, 2021 at 7:11 PM
    Wulf
    rock raisin
  6. Sep 30, 2021 at 7:12 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    .jpg
    Kwikvette[QUOTED] likes this.
  7. Sep 30, 2021 at 7:13 PM
    Wulf
    rock raisin
    That's nuts
  8. Sep 30, 2021 at 7:17 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    DN
    Kwikvette likes this.
  9. Sep 30, 2021 at 7:19 PM
    Running Board Man
    Someone at some point fucked up the u joint phasing on my neighbors tundra when they replaced the carrier bearing so I just put the u joints back in phase and it drove smooth as glass
    Cept on tundras the driveshaft isn't bolted together it's in only got a u joint joining the 2 halves so yeah
  10. Sep 30, 2021 at 7:21 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I actually use that stuff; it's awesome and I've been using it for years!
    treyus30[QUOTED] likes this.
  11. Sep 30, 2021 at 7:22 PM
    Running Board Man
    Some girls like the rich flavor that can only develop over time like aging cheese
  12. Sep 30, 2021 at 7:24 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    I'm down a rabbit hole again. Lug centric vs hub centric wheels. Some argue SCS wheels are still lug centric so that's a fun argument. It all started today when I purchased those Enkei wheels locally including the expensive center caps for $100. Need to measure their hub bore and see if they could technically be considered hub centric.
    Then I remembered my dad has a terrible vibe on his 2008 (I called it an 09 the other day by mistake) and it could technically just be his Raceline wheels with a 108mm hub bore. He had tires, wheels, and the rough country "lift" put on all at once. But I'm still thinking the wheels are most suspect.
    Running Board Man likes this.
  13. Sep 30, 2021 at 7:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Says the single guy :laughing:
  14. Sep 30, 2021 at 7:26 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Oh no
  15. Sep 30, 2021 at 7:26 PM
    JKO1998
    Utah
    Maybe he likes the flavor and just assumed
  16. Sep 30, 2021 at 7:28 PM
    eon_blue
    Azusa, CA
    things Texans say for $500 Alex
  17. Sep 30, 2021 at 7:32 PM
    Running Board Man
    Hub centric all day long, don't need the extra ugga duggas tire shops tend to add on there risking my wheel falling off any more than it already is
  18. Sep 30, 2021 at 7:34 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I figured a texan would liken it to dry aged steak
  19. Sep 30, 2021 at 7:35 PM
    04Pre_Runner
    Andrew
    Might sell these Enkei hub caps for $80 a pop and scrap the wheels if I determine they are lug centric. Already a pain having to use non-standard lugs. And these are the least popular Enkei wheels since they look so similar to stock wheels.
    200071532_10227055940609838_162075812072_a215c5a2e4d77afe1d28370b6f7af260525e9f4b.jpg
  20. Sep 30, 2021 at 7:36 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Wowee. im only getting 275ish before its too sus
