  1. Oct 16, 2021 at 5:30 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I guess I should probe the cord for continuity
  2. Oct 16, 2021 at 5:50 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
  3. Oct 16, 2021 at 5:52 PM
    eon_blue
    Azusa, CA
    Ditch lights on the fucking skid plate, now I think I've seen it all
    jubei, 0xDEADBEEF, Wulf and 1 other person like this.
  4. Oct 16, 2021 at 5:53 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  5. Oct 16, 2021 at 6:00 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Did you find a how to on that or just make it up as you go? This is something I gotta do soon too and those spring compressors do look sketchy.
    04Pre_Runner[QUOTED] likes this.
  6. Oct 16, 2021 at 6:02 PM
    0xDEADBEEF
  7. Oct 16, 2021 at 6:05 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Did you have to loosen the alignment cams?
    I tried that method once and gave up because the spring was still preloaded with the arm at full droop. I think it would have been fine with cams loosened, but I didn't want to mess with the cams at the time.
  8. Oct 16, 2021 at 6:37 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Check all of your neutral connections at the bus bar in the panel and on the outlets. Loose neutrals can cause inconsistent voltage readings.
    Also, get that dryer on its own breaker asap. Double tapping a breaker is a no-no. You get a home inspection? If so, the inspector should have written up a double tapped breaker.
  9. Oct 16, 2021 at 6:54 PM
    Running Board Man
    Running Board Man Well-Known Member
    The bushings still being tight inhibits their ability to pivot
    So yes loosen the cams if you want to do this
    04Pre_Runner likes this.
  10. Oct 16, 2021 at 7:09 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I was literally in that aisel today and made me think of your camper seal problem
    Das it mang[QUOTED] likes this.
  11. Oct 16, 2021 at 7:09 PM
    0xDEADBEEF
  12. Oct 16, 2021 at 7:13 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Fucking Prime
    04Pre_Runner and Black DOG Lila like this.
  13. Oct 16, 2021 at 7:19 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Be careful dude. Thems firey territory (something's loose).
  14. Oct 16, 2021 at 7:30 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Big wheeling weekend. Lots of water crossings and rocks.
    The 80 series stopped running. No spark or fire. We think it might be the fusible link.
  15. Oct 16, 2021 at 7:40 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Yup. I felt like a genius after reading all these salty 1st gen owners saying the method wouldn’t work for our trucks. Even worked with my sketchy spacer pucks. My spring compressors (made for MacPherson struts) wouldn’t fit between the coils to compress them. So this was my only option.
    Watched a video for 2nd gens and determined it didn’t make sense for our application. So made it up as I went. Alignment cams were hand tight which is fine since my control arms were off to begin with. This method may not be successful with a really long coilover. Would be hard to get a good point for the jack with the arms at such an angle.
  16. Oct 16, 2021 at 8:32 PM
    0xDEADBEEF
    Is there anything more simultaneously relaxing and stressful as visiting parents?
  17. Oct 16, 2021 at 8:41 PM
    Wulf
    rock raisin
    Trusting a fart
    treyus30 likes this.
  18. Oct 16, 2021 at 8:45 PM
    0xDEADBEEF
    :rofl:
    Yes.
  19. Oct 16, 2021 at 9:09 PM
    6P4
    Colorado Springs
    Well, I finally got around to installing the Softopper I bought a while back. The white canvas looks great with the Surfside Green paint, except... it doesn't fit. It's about 6", maybe even 8" too narrow. This thing must have been made for a Stepside truck.
  20. Oct 16, 2021 at 9:11 PM
    Wulf
    rock raisin
    ah damn lol
