  1. Nov 16, 2021 at 6:50 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
  2. Nov 16, 2021 at 6:51 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Boy, all you had to do was attach them
  3. Nov 16, 2021 at 6:58 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    1uz is even cheaper
  4. Nov 16, 2021 at 6:59 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That was like 3 years ago :rofl:
    Das it mang[QUOTED] likes this.
  5. Nov 16, 2021 at 7:02 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    I know i know, had to bench everything after having a fall through with the gf. promise ill get on it :D
    Kwikvette[QUOTED] and what road like this.
  6. Nov 16, 2021 at 7:03 AM
    Speedytech7
    Lighter and more stout in the rotating assembly too. But I think the 3UZ is the best value in power, weight, and upgrade path.
  7. Nov 16, 2021 at 7:15 AM
    Wulf
    rock raisin
    350k junkyard silverado LS FTW :luvya:
    Kwikvette, Abeyancer and 04Pre_Runner like this.
  8. Nov 16, 2021 at 7:16 AM
    Wulf
    rock raisin
    when its noisy does the fluid look foamy/aerated?
    CS_AR[QUOTED] likes this.
  9. Nov 16, 2021 at 7:17 AM
    Speedytech7
    Yeah that can be fun too, not stock, but with a cam, intake, and a cheapo tune.
  10. Nov 16, 2021 at 7:18 AM
    Wulf
    rock raisin
    I love the sound of UZ swaps with basic cheap turbo style mufflers :D
  11. Nov 16, 2021 at 7:20 AM
    Wulf
    rock raisin
  12. Nov 16, 2021 at 7:23 AM
    Speedytech7
    Technically a junkyard engine...
    Kwikvette and 04Pre_Runner like this.
  13. Nov 16, 2021 at 7:24 AM
    Wulf
    rock raisin
    that is a clean fit
    must be a fun driver too :D
  14. Nov 16, 2021 at 7:29 AM
    Speedytech7
    It's pretty entertaining, but not super fast yet. It's an all aluminum LH6 5.3 with a brian tooley racing stage three truck cam. Needs spicier tune, I have the ignition timing map set pretty aggressive but I'm 90% sure that carburetor is holding it back.
    https://youtu.be/aHgQk12jev8
    Wulf[QUOTED] and 04Pre_Runner like this.
  15. Nov 16, 2021 at 7:40 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Why didn't you go with EFI again?
    Kwikvette likes this.
  16. Nov 16, 2021 at 7:43 AM
    Speedytech7
    Because my buddy who I did all the wiring and much of the assembly with is afraid of EFI and thought he was going to have to wire it all. I would have been happy to do it cause it would easily be 75+ HP more and a ton more under the curve where the carb is responding poorly. This dynod with its poop carb tune at 262hp at the wheels, thats through a 700R4 and with 285/60/18 tires and a 3.73 axle ratio. So it's maybe a 330hp engine, it should be much better than that.
  17. Nov 16, 2021 at 7:46 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    No foam. I can see the fluid circulating in the reservoir as it should. I can feel the whine vibrations being transmitted through the larger supply hose. When I turn the wheel slightly the whine stops for a few minutes. Sometimes when I make clock-to-clock turns the steering becomes jerky and the while really gets loud -- but not every time.
  18. Nov 16, 2021 at 7:47 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Sounds like you will be swapping to EFI either way eventually. I see no reason to run carbs on anything any more unless you are trying to keep a restored vehicle 100% stock.
  19. Nov 16, 2021 at 7:52 AM
    Speedytech7
    I offered to do it for him, we have three other assembled LS engines with carbs on top and I told him now is the time to learn and plan, cause otherwise you have two (much more expensive engine swaps) that are also going to disappoint on deck. Even a TBI kit would perform much better, but ideally I'd like to warm him up to MPFI, and hell these LS engines are ready for it all anyway, we still have stock truck manifolds that I could demonstrate on.
    xtremewlr[QUOTED] likes this.
  20. Nov 16, 2021 at 7:54 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, there are a ridiculous number of options for the LS when it comes to injection of any kind. Not super hard to do any more, I have no doubt there are complete plug and play kits for most anything with hardly any real wiring to do.
