  1. Nov 16, 2021 at 7:57 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah, and honestly even the tuning I find much easier, sure theres more than using a screwdriver, but the result is better
    Kwikvette and xtremewlr[QUOTED] like this.
  2. Nov 16, 2021 at 8:19 AM
    Wulf
    rock raisin
    interesting
    how is the rack/box?
    CS_AR[QUOTED] likes this.
  3. Nov 16, 2021 at 8:22 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  4. Nov 16, 2021 at 8:24 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    What do you guys think my King 2.5 with reservoirs (non-adjustable) shocks are worth?
    They've got about 9k miles on them.
    One of them needs a reservoir replaced, then nitrogen charge of course. I have a reservoir and sticker to replace with.
    Also including new steel and nylon sleeves as well as bushings (top mount is stem).
    Been quoted 60-80 for the labor for the reservoir job.
    Might be looking to trade for some 12" Kings for my relocation but his need a rebuild.
  5. Nov 16, 2021 at 8:28 AM
    JKO1998
    Utah
    Rebuilds aren’t that spendy if that means anything
  6. Nov 16, 2021 at 8:37 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    @Empty_Lord will give ya $5 I bet. He's a cheap bastard. :rofl:
    Kwikvette[QUOTED] likes this.
  7. Nov 16, 2021 at 8:37 AM
    JKO1998
    Utah
    Thinkin ima start carrying around an engine lift crane thing
    Abeyancer likes this.
  8. Nov 16, 2021 at 8:38 AM
    eon_blue
    Azusa, CA
    I sent an email to their contact page last night and got an email this AM it will be delivered today, someone just dropped the ball on sending out shipping info but nbd
  9. Nov 16, 2021 at 8:38 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
  10. Nov 16, 2021 at 8:40 AM
    JKO1998
    Utah
    I’ve been thinking about trying to find a way to get my winch line under the truck to the other side and hi enough I could use it as a lift. But I haven’t got much passed thinking about it
  11. Nov 16, 2021 at 8:41 AM
    JKO1998
    Utah
    Looks at balljoint club membership*
    Kwikvette likes this.
  12. Nov 16, 2021 at 8:43 AM
    eon_blue
    Azusa, CA
    Don't you put that voodoo on me, just gotta make it another 4 days
  13. Nov 16, 2021 at 8:43 AM
    Speedytech7
    Lemme do a bit of research and see if they work for an LC, we have a similar stock rear setup, I might want em
  14. Nov 16, 2021 at 8:52 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Nearly new. About 1 year old. My buddy from TX that has made a couple of runs in the Ozarks with me now has a screaming PS pump after he got home from last weekend's trip.
    There is some kind of stress that we must be putting on the pumps that causes the vanes to start howling. Changing fluid weekly when it starts seems to help.
    The strange thing is I have several friends with 80 series and Tacomas that run the same trails and put the same or more stress on their steering systems, have no problems.
    The 80 series reservoir is a different design. I'm starting to think there may be some condition we get into on trails that contributes to the problem.
    Do you guys know of any racing PS fluid that can handle extra high temps? @Speedytech7
    Maybe I need to install another "larger" PS fluid cooler.
  15. Nov 16, 2021 at 8:54 AM
    Speedytech7
    Have you looked into the synthetic pentosin? Wits end makes a larger cooler for 80series too that probably fits a hundo. But honestly it shouldn't be getting that hot, is your pressure regulator sticking maybe?
    CS_AR[QUOTED] and Wulf like this.
  16. Nov 16, 2021 at 8:56 AM
    Wulf
    rock raisin
    Yeah, when you mentioned steering angle changed pump noise I was wondering if there was an internal issue in the box causing added strain or reduced flow, though it could just be a noisy pump under load.
    Some people swear by Amsoil or Royal Purple in racing or rock crawling systems that see high heat-- ATF additives are a no-go for hydraulic cylinders and orbital values that hydro assist/full hydro systems run. at the end of the day ATF is hydraulic fluid with extra additives for the transmission application.
    I have run the Amsoil and noticed less boiling over compared to mineral power steering fluid. That said I've been running ISO32 hydraulic oil in the crawler and it does dandy
    edit: @Speedytech7 is right that it shouldn't be getting too hot though
  17. Nov 16, 2021 at 9:10 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    And his reasoning would be to "help for shipping" :rofl:
    xtremewlr[QUOTED] likes this.
  18. Nov 16, 2021 at 9:11 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It's more the hassle of finding someone to do it right
  19. Nov 16, 2021 at 9:13 AM
    eon_blue
    Azusa, CA
    I would send them to Accutune down here. They're legit
  20. Nov 16, 2021 at 9:14 AM
    Speedytech7
    @Kwikvette which kings are those, got a link?
