  1. Nov 19, 2021 at 12:18 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I have the A442F, level 10 doesn't do those. Wholesale Automatics makes a bulletproof one for the aus market
    04Pre_Runner and CS_AR[QUOTED] like this.
  2. Nov 19, 2021 at 12:24 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    @Speedytech7 red pill me on A340F upgrades? I'm expecting to explode mine someday
  3. Nov 19, 2021 at 12:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh man, you should ask @Empty_Lord about all the different MR2s I'd easily find out here.
    Some were stupid clean, all stock, low mile turbo variants too.
    Whatcha looking for exactly?
  4. Nov 19, 2021 at 12:32 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Apparently a common MR2 engine swap is the 5VZ
    04Pre_Runner likes this.
  5. Nov 19, 2021 at 12:32 PM
    Speedytech7
    Step one is probably just seeing if you have your throttle valve cable adjusted per the FSM, that really helps a ton, they stretch over time. Aisin is smart and unlike the domestic trans offerings they don't use bands, they use stronger braking clutch packs so they don't wear out as often or dirty fluid as easily. Next step after checking your adjustment would be to shim the accumulators (or change springs in them) and use a shift reprogramming kit from transgo to get faster 2-3 and 3-4 shift engagement times, reduces wear on the higher stress clutch packs. After that it becomes a full build where you have to rebuild the trans pump for higher flow and change to kolene steels and try to machine it out for another clutch to fit in each drum.
  6. Nov 19, 2021 at 12:34 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Cool, thanks!
    What about stronger adaptations? I heard somewhere a Supra transmission might be compatible and stronger from factory?
  7. Nov 19, 2021 at 12:37 PM
    treyus30
    Trey
    Mesa / AJ, AZ
  8. Nov 19, 2021 at 12:39 PM
    Speedytech7
    I don't think the supra ones are any stronger, the internal design is almost identical besides the ratios. There are 5 or 6 different revisions of the A340 electronic transmissions that change the valvebody layouts rather dramatically, but functionality seems to be the same. Because of the Supra having used a A340 variant though, there are lots of performance internals available that should fit, billet input shafts, larger drums, intermediate shafts...etc
  9. Nov 19, 2021 at 12:44 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Soooo
    hows P0120 to fix?
  10. Nov 19, 2021 at 12:45 PM
    Speedytech7
    TPS is ded, order new one and adjust accordingly, well check the wiring first, could be simple
    04Pre_Runner and treyus30 like this.
  11. Nov 19, 2021 at 12:45 PM
    JKO1998
    Utah
    TW says to try and clean it
  12. Nov 19, 2021 at 12:46 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    TW is ghey
  13. Nov 19, 2021 at 12:48 PM
    JKO1998
    Utah
    Spider man pointing at spider man meme*
    04Pre_Runner, Kwikvette and Abeyancer like this.
  14. Nov 19, 2021 at 12:50 PM
    treyus30
    Trey
    Mesa / AJ, AZ
  15. Nov 19, 2021 at 12:51 PM
    JKO1998
    Utah
    Oh hell that’s a simple
    can I just steal the 99’s?
  16. Nov 19, 2021 at 12:59 PM
    Wulf
    rock raisin
  17. Nov 19, 2021 at 1:12 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Sounds like someone got an underthepants handy in the Hardee's drive thru
    Woodini and High Noon like this.
  18. Nov 19, 2021 at 1:14 PM
    Woodini
    Woodini Well-Known Member
    Ray
    Daytona Beach Shores
    89 Pickup 22RE 4wd
    LCE i/h/e OME susp (install soon) 17” fn counter steer, gonna buy new rubber
    Those greasy hands
    04Pre_Runner and Abeyancer like this.
  19. Nov 19, 2021 at 1:17 PM
    Speedytech7
    Hardee's? or the handy?
  20. Nov 19, 2021 at 1:18 PM
    Wulf
    rock raisin
