  1. Dec 5, 2021 at 9:31 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Hm. I think usually a slipping clutch shows itself in the high gears since that’s where you’re putting more torque through it. But this is a crawler so a lot of torque could be in at the low gears too.
  2. Dec 5, 2021 at 9:32 AM
    0xDEADBEEF
    Just bolt some snow plow headlights to the hood
  3. Dec 5, 2021 at 9:35 AM
    Wulf
    rock raisin
    Yeah in 4 low you have the torque to push the clutch in any gear if you have enough traction lol
    0xDEADBEEF[QUOTED] likes this.
  4. Dec 5, 2021 at 9:36 AM
    Wulf
    rock raisin
    I told my friend I'd build a tube bumper for it with some LED pods instead of fixing it
    On the other hand it would be nice to avoid any extra attention
  5. Dec 5, 2021 at 9:37 AM
    Wulf
    rock raisin
  6. Dec 5, 2021 at 9:40 AM
    0xDEADBEEF
    Needs a flatbed
  7. Dec 5, 2021 at 9:40 AM
    Wulf
    rock raisin
    It just occurred to me that pulling the core support without deleting the airbags is gonna be a bad time lol
  8. Dec 5, 2021 at 9:43 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I’m almost done with the vapor barrier.
    But I’m trying to make the space as sound isolated as possible, so I “had to” frame a double wall in, wire in two new circuits, and do double the insulation. Apparently I also “had to” cut in a skylight at some point too.
    Once I’m done with the vapor/air barrier, it’s time for whisper clips and hat channel. Then two layers of drywall with green glue between them.
    What I should have done was just leave it at only the exterior walls, wire it up, slap some insulation in the bays and get the drywall and mud/tape out of the way as soon as possible.
    Instead, here I am…
    0xDEADBEEF likes this.
  9. Dec 5, 2021 at 9:44 AM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Core support should only take you a few hours. On the Tacoma the only thing that really sucked is the ac line has to discharge because it runs through the core support. On the 4runner I said fuck it and just hammered it back to shape.
    Wulf[QUOTED] likes this.
  10. Dec 5, 2021 at 9:49 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  11. Dec 5, 2021 at 10:08 AM
    Wulf
    rock raisin
    You familiar with the Sentras?
    Running Board Man likes this.
  12. Dec 5, 2021 at 10:09 AM
    Wulf
    rock raisin
    Yeah that Tacoma core support is annoying lol
    Mine needs to be repaired or replaced. It's cracked on both sides under the headlights. I fear that if I weld/reinforce it there it will break somewhere else lol
    Tour991[QUOTED] likes this.
  13. Dec 5, 2021 at 10:10 AM
    Wulf
    rock raisin
    Alright I've had a sufficiently lazy morning maybe I will find some inspiration for Toyota time
  14. Dec 5, 2021 at 10:10 AM
    Wulf
    rock raisin
  15. Dec 5, 2021 at 10:22 AM
    Tour991
    James
    South Reno/Tahoe
    Mine tore in the same spots and above the passenger head light. I ordered an aftermarket one on eBay. I wasn't expecting much but surprisingly it lined up almost perfect.
    Abeyancer likes this.
  16. Dec 5, 2021 at 10:35 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Just to think about the money I've spent when I could have had a Taurus.
    This thing goes. It has a hidden winch. It gets in there and wheels with the best of them.
  17. Dec 5, 2021 at 10:35 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Another Boltr fan I see
  18. Dec 5, 2021 at 10:37 AM
    Running Board Man
    Running Board Man Well-Known Member
    why?
  19. Dec 5, 2021 at 10:41 AM
    Running Board Man
    Fwds in reverse can get up a LOT of stuff that you wouldnt expect it to
    Das it mang and CS_AR[QUOTED] like this.
  20. Dec 5, 2021 at 10:41 AM
    Abeyancer
    Jimmie
    PNW
    That's alotta sound proofing.. this you?
    jubei[QUOTED] likes this.
