  1. Dec 6, 2021 at 9:20 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Better fork it over, he seems serious
    Kwikvette[QUOTED] likes this.
  2. Dec 6, 2021 at 9:20 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    unstpible, Wulf, Das it mang and 2 others like this.
  3. Dec 6, 2021 at 9:21 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I am serious, and don't call me Shirley.
  4. Dec 6, 2021 at 9:23 PM
    0xDEADBEEF
    Wulf, jubei, CS_AR and 2 others like this.
  5. Dec 6, 2021 at 9:24 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    YOUTS
    0xDEADBEEF[QUOTED] likes this.
  6. Dec 6, 2021 at 9:29 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    ive got a m161 gasser. trying to keep it a gasser. thanks though.
    the straight 5 also wont fit very easily with this cars overly short hood.
  7. Dec 7, 2021 at 6:05 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Fuck Kohler in general. I used to have to deal with their CEO and executive team at a past job and they are a bunch of arrogant assholes.
    unstpible and Abeyancer[QUOTED] like this.
  8. Dec 7, 2021 at 6:12 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I don't think I've filled my manuals any other way.
    unstpible likes this.
  9. Dec 7, 2021 at 6:19 AM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Horn on the 99 won’t work reliably in cold weather. It’s funny because the piezo buzzer on my RS3000 Toyota keyless system only works below ~45 degrees.
    I’m guessing clockspring/spiral cable. I’ll have to dig into it later when the 04 is back driving.
  10. Dec 7, 2021 at 6:19 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Don't forget the zip tie.
  11. Dec 7, 2021 at 6:23 AM
    CS_AR
    Knows Chevy engines.
    jubei and 0xDEADBEEF[QUOTED] like this.
  12. Dec 7, 2021 at 6:41 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  13. Dec 7, 2021 at 6:45 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    p easy process? Might do it bc i need to change the shifter bushing as well.
    pops out of third sometimes when im engine braking and hit a bump
  14. Dec 7, 2021 at 6:49 AM
    0xDEADBEEF
    Just have a way to seal it back up when you're done. I just used RTV.
    Definitely pretty easy so long as you don't spill that lovely smelling oil in the cab.
  15. Dec 7, 2021 at 6:49 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  16. Dec 7, 2021 at 7:10 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Well that's just par for the course then. Their engines are shit, for a lot of reasons.. but my biggest gripe is their "workaround" to deal with emissions. Every other small engine sold in the US made at least a small effort in changing actual engine efficiency to reduce emissions.
    Kohler's solution? "JUST LEAN THAT CARB OUT BRO!" don't run the engine at night, you might think something is wrong 20211207_070324.jpg
    unstpible and slander[QUOTED] like this.
  17. Dec 7, 2021 at 7:17 AM
    slander
    Hickory, NC
    Yea it's pretty easy. You need to take the console apart, but I would take off 10 screws on the interior of the truck over laying on my back dumping gear lube on myself anyway. See if Toyota has a cork or paper gasket for the shifter, then you don't have to dick around with RTV. I'm trying to think if my trans even has a gasket or seal on the shifter. Also I would just dump 3qts in there and not even worry about overfilling it a bit, if anything I will help keep the trans slightly cooler, it's all splash lubed anyway. The hardest part about servicing it from the bottom IMO is working around the damn driveshaft.
    Oh you may as well do the tcase while you have the console apart.
  18. Dec 7, 2021 at 7:20 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Mine had a paper gasket and you have to be careful not to tear it. Some parts stick to the trans and some to the shifter.
  19. Dec 7, 2021 at 7:23 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    fingers crossed i dont spill. I will check for paper or cork gasket around, but rtv in the end i guess if i come up short. What color rtv should i put on there? definitely dont mind removing 10 screws. 5 lug means no tcase ;)
    thank u all again for being so helpful
    unstpible and Wulf like this.
  20. Dec 7, 2021 at 7:26 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Any RTV that works for the oil pan should work.
