  1. Dec 9, 2021 at 12:53 PM
    eon_blue
    Azusa, CA
  2. Dec 9, 2021 at 12:54 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Heh.. I didn't start carrying tools and spare parts until I started driving a Lexus.
    We definitely have a list of "don't go too far from home without them" parts and tools so we can perform service in the field. But is this a rice, soybean, or cotton field? :rofl::rofl::rofl:
    And then there are the specialty tools like a 54mm socket, Proto snap knurly end ring pliers, locally developed CV Axle puller,,,
    0xDEADBEEF[QUOTED] likes this.
  3. Dec 9, 2021 at 12:55 PM
    CS_AR
    I need to air up to get more ground clearance. That's my problem. :crazy:
  4. Dec 9, 2021 at 1:02 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Split rim wheels are scary as hell
  5. Dec 9, 2021 at 1:13 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Tannerite the obstacles for better clearance.
    CS_AR[QUOTED] likes this.
  6. Dec 9, 2021 at 1:15 PM
    CS_AR
    A few years ago I had a cat ordeal with some 4th gen Maximas. So everybody except CA and NY residents installed a special y-pipe to delete the pre-cats. The cars would still pass an exhaust inspection without the pre-cats so this was legal in 48 states.
    Then we installed some type of Magnaflow high-flow cat that was a generic design that some reported was actually designed for a Buick Roadmaster. The idea was to keep only enough cat to keep the rear O2 sensor happy.
    Some people reported HP gains of from 10 to 15 using a butt dyno. The engines do run cooler without the pre-cats and I can feel the difference with the y-pipe. Note the y-pipe looks like the current Tacoma V6 catless pipe. My pre-cats had been roasted and became clogged from leaking fuel injectors, so the cat delete was necessary to keep it running.
    All was good for about 18 months. Then comes code P420. Reset it and that lasts for a month and comes right back. Soon it would stay on all the time.
    A few of the club members held on to their original cats and quickly reverted back once the word was out about the P420 problem. I think 4 or 5 guys all had this problem around the same time.
    Like an idiot, I let my kid take the cat to the metal salvage place and get some money for it. I did manage to keep one stock car around by some miracle. I have two cars with the same exhaust setup.
    About that time the club discovered Walker cats would remedy the code problem. So everybody ran to Rock Auto and bought Walker cats for that model car. Many made complete Walker stainless exhaust system replacements. The walker cat has been running for roughly 5+ years without issue. OEM cats are now unobtanium.
    When I'm faced with replacing the Lexus 470 cats that I suspect has a cat rattle, I will most likely go back to a premium Walker from Rock Auto. The Walker cat could fail tomorrow. Until then, no complaints.
    Abeyancer and eon_blue[QUOTED] like this.
  7. Dec 9, 2021 at 1:18 PM
    eon_blue
    Azusa, CA
    Yeah I am really hoping I don't have to replace the cats again. Not only are they crazy expensive right now, but to have my cats fail again would have to mean that some fuckery is going on with my truck. As far as I can tell, there isn't though... I monitor my AFR readings with a Wideband gauge and they have been normal. Nothing unusual in open or closed loop. Would surprise me if that were the case
    CS_AR[QUOTED] and 04Pre_Runner like this.
  8. Dec 9, 2021 at 2:23 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  9. Dec 9, 2021 at 3:00 PM
    CS_AR
    How old were your OEM cats when they failed? Do you have one cat or 3 or 4? I don't think you have high mileage?
  10. Dec 9, 2021 at 3:08 PM
    Jase
    Jase Well-Known Member
    jase
    Oregon
    2004 4x4 DC
    Rebuilt / frame swap at 200K
    Frame
    04Pre_Runner likes this.
  11. Dec 9, 2021 at 3:11 PM
    eon_blue
    Azusa, CA
    I have 2 cats, front & rear. First ones failed at about 50k miles on the odo (the OEM ones). Which was very early of course.
    But, the PO supercharged the truck and didn't add any fuel mods so I am fairly certain running it lean is was killed the cats quick. I replaced them with the Magnaflows and added the URD 7th injector, plus a Wideband AFR to monitor AFR numbers, which have been much better (normal) since. I'm at almost 100k miles now.
    I'm also very in tune with how to drive the truck to keep it from pinging in certain conditions, avoiding high gear/low RPM is crucial for this. I have no idea how the PO drove it, but for all I know he was lugging it up highway grades in 5th gear and ignoring the signs.
  12. Dec 9, 2021 at 3:25 PM
    BartMaster1234
    Tyler
    Flux Capacitor
  13. Dec 9, 2021 at 3:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Those 120 brackets I drilled?
    I need to weld them together, so I made a jig.
    Used the first one as my "base"
    The cuts aren't always perfect, but the welded product has to be.
    Abeyancer, Tour991, CS_AR and 7 others like this.
  14. Dec 9, 2021 at 5:54 PM
    CS_AR
    I haven't seen much about running lean destroying cats. Burning valves yes. I can state with all certainty that running too rich (uncontrolled fuel) will heat up the cat to the point where it melts the catalyst. Are your O2 sensors the originals fairly recent?
  15. Dec 9, 2021 at 5:57 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I can’t see that. Where is it at by chance? (No Facebook)
  16. Dec 9, 2021 at 5:59 PM
    Empty_Lord
    Dan
    @eon_blue sadly aftermarket cats usually start to throw codes after 4-5 years. My magnas were getting weak by the time the truck was torn apart.
    CS_AR likes this.
  17. Dec 9, 2021 at 6:06 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Nothing like forklifting while it's snowing. That shit gets cold!
    BartMaster1234, CS_AR and Kwikvette like this.
  18. Dec 9, 2021 at 6:33 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    @Kwikvette
    I haven't caught up over the last few pages, but saw you talking about the Coastal bumpers. Mine came pretty quick (ordered and to my door in 3 weeks) and was pretty easy. Hardest part for me was all the prep work (Lexus makes it difficult with the built in air compressor and idiotic mounting points). Prepping, priming and Raptorlining was harder than welding/fitting it. Would recommend...
  19. Dec 9, 2021 at 6:35 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Hell yeah, that looks badass.
    Seeing that they're just a bunch of plates, that looks way easy to weld.
    Doing a dual swing out it looks like?
    Looks bitching
  20. Dec 9, 2021 at 6:37 PM
    Running Board Man
    Running Board Man Well-Known Member
    Fuck pitman arms
    IMG_20211209_152810633.jpg IMG_20211209_152823656.jpg IMG_20211209_153106803.jpg IMG_20211209_153103132.jpg IMG_20211209_152816951.jpg
    04Pre_Runner and Das it mang like this.
