  1. Dec 13, 2021 at 8:35 AM
    eon_blue
    Azusa, CA
    You're free to salvage what you can from the wreckage
  2. Dec 13, 2021 at 8:36 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's worth waiting for I think. I don't envy the position you're in to get through emissions. Do you have to go on the dyno still or is it just OBDII
  3. Dec 13, 2021 at 8:38 AM
    eon_blue
    Azusa, CA
    No dyno thankfully, only <2000 years have to get dynoed. Just obdII and visual check. Usually takes 5 min and I'm done
  4. Dec 13, 2021 at 8:39 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Can the sway bar move side to side,
    Abeyancer[QUOTED] likes this.
  5. Dec 13, 2021 at 8:40 AM
    eon_blue
    Azusa, CA
    Have her ditch the sway bar, tell her it's a TW approved mod
    Kwikvette and Abeyancer[QUOTED] like this.
  6. Dec 13, 2021 at 8:42 AM
    Speedytech7
    Ah okay, up until emissions testing was removed in WA they made you dyno everything below 1996 and everything else just got an emissions check through OBDII. I'm glad they removed the testing altogether, it was a losing battle for the state to maintain.
    Abeyancer likes this.
  7. Dec 13, 2021 at 8:43 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    No the sway bar is tight all the way around... I didn't swap bushings in the trailing arms (the ones that hold the hub to the frame?) When I jack it up those are tight as well but the only thing I haven't changed
  8. Dec 13, 2021 at 8:43 AM
    Abeyancer
    Jimmie
    PNW
    :rofl:
    If she didn't like driving it like a go kart I'd push harder on that
    Kwikvette and eon_blue[QUOTED] like this.
  9. Dec 13, 2021 at 8:45 AM
    eon_blue
    Azusa, CA
    Yeah the dyno/sniff test is some BS I'm glad I don't have to put up with. Failing due to your exhaust gas readout even with no codes would suck to deal with.
  10. Dec 13, 2021 at 8:48 AM
    Speedytech7
    Yeah, TBH the LC had to be tested when I first got it and I have zero idea how it passed. It very obviously runs quite rich and the cats at that point were 24 years old, no spring chickens. I sorta worked backwards on that one though, I have since gotten it running less rich and even put a CARB certified cat from a 94 Supra on it and now it only smells on startup.
    eon_blue[QUOTED] likes this.
  11. Dec 13, 2021 at 9:08 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Empty_Lord likes this.
  12. Dec 13, 2021 at 9:08 AM
    Empty_Lord
    Dan
    Thank ya!
  13. Dec 13, 2021 at 9:09 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Happy Birthday @Empty_Lord
    You must be at least a little excited?!
    Maybe throw a small party?
    Speedytech7[OP] likes this.
  14. Dec 13, 2021 at 9:09 AM
    Empty_Lord
    Dan
    Loud clutch from the rear show show itself as something obvious on those. Jack it up and wiggle the wheels, etc. make sure end links are tight tight and installed the right direction
  15. Dec 13, 2021 at 9:09 AM
    Empty_Lord
    Dan
    I appreciate the happy birthday. But damnit man. I’m only 1” shorter than you!
    Kwikvette[QUOTED] and Abeyancer like this.
  16. Dec 13, 2021 at 9:10 AM
    Speedytech7
    Did realize you guys were measuring that close
  17. Dec 13, 2021 at 9:12 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You must've missed all the 5'11" memes :rofl:
  18. Dec 13, 2021 at 9:21 AM
    eon_blue
    Azusa, CA
    Can confirm
    I'm 5'11 rounded up to 6'
    Kwikvette[QUOTED] likes this.
  19. Dec 13, 2021 at 9:22 AM
    Speedytech7
    I feel like you'd be short even if you said you're 5'12", it only becomes real if you've got a 6 there.
    Kwikvette, CS_AR and eon_blue[QUOTED] like this.
  20. Dec 13, 2021 at 9:29 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    5’ 6.1” ftw
