  1. Dec 13, 2021 at 12:01 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    You at the junkyard
  2. Dec 13, 2021 at 12:02 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Abeyancer[QUOTED] likes this.
  3. Dec 13, 2021 at 12:08 PM
    Abeyancer
    Jimmie
    PNW
    On a FWD car, do the rear sway bar bushings need to be torqued down when the vehicle is supported by its own weight?
    Not the end links, the actual bar itself
  4. Dec 13, 2021 at 12:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  5. Dec 13, 2021 at 12:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Are you experiencing side fumbling?
  6. Dec 13, 2021 at 12:09 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Just a reminder of what we talked about on the trail, get the new sockets and seats for your manual trans and tcase, you're gonna start losing gears eventually at your trucks age if you don't change them now.
    https://www.marlincrawler.com/shifter-parts/new-heavy-duty-seat-socket-combo
    The yellow highlighted option get you all three you need...
  7. Dec 13, 2021 at 12:10 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    I would say no but it probably depends on the car.
  8. Dec 13, 2021 at 12:10 PM
    Abeyancer
    Jimmie
    PNW
    It's my favorite video to express how something can sound smart but make absolutely zero sense lol
    Kwikvette[QUOTED] likes this.
  9. Dec 13, 2021 at 12:10 PM
    Speedytech7
    yes, suspension as a rule should be torqued on the ground and settled
    CS_AR and Abeyancer[QUOTED] like this.
  10. Dec 13, 2021 at 12:11 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Super highly recommended. I need to get a new seat for the FJ tcase in my 4Runner.
  11. Dec 13, 2021 at 12:11 PM
    Abeyancer
    Jimmie
    PNW
    It's the wife's 01 corolla. No side fumbling but after changing the rear struts assemblies sway bar end links and now sway bar bushings, it had a really loud clunk when she drives over big bumps (like railroad tracks)
  12. Dec 13, 2021 at 12:11 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Shouldn't the bar articulate regardless of if it's torqued down or not? The torsion comes from the difference between relative end link heights.
  13. Dec 13, 2021 at 12:13 PM
    Speedytech7
    It still gets trapped in a resting position, if you can easily rotate the bar in its bushings the bushings are toast
    Abeyancer likes this.
  14. Dec 13, 2021 at 12:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just following our trucks rule, I'd only torque to spec while on the ground.
    You sure everything is "seated" correctly?
    Btw the side fumbling was a ref to your video :laughing:
  15. Dec 13, 2021 at 12:13 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Had that on my R when I first bought it. End links were seizing. Sprayed with lube and not had an issue since.
  16. Dec 13, 2021 at 12:13 PM
    Abeyancer
    Jimmie
    PNW
    Mmmmkay, imma try that then.. I did all of it still on javkstands so maybe that's my issue
  17. Dec 13, 2021 at 12:13 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I can't remember if I added these to my G-trans in the 84 4Runner. That trans isn't going to last long behind the 3RZ I swapped in so I guess it wont really matter in the long run.
  18. Dec 13, 2021 at 12:16 PM
    Abeyancer
    Jimmie
    PNW
    I'm honestly not sure it's all seated the way it should be.. it's so hard to get to those lower strut bolts with the tire on so I did it up in the air.
    Good call back on the side fumbling, it tripped me up cause I thought you were referring to the car swaying back and forth:laughing:
  19. Dec 13, 2021 at 12:17 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Well... I can easily rotate it or pull side-to-side in the trucks with it disconnected from the end links; I think you'd have shot bushings if you could get up-and-down play too
  20. Dec 13, 2021 at 12:17 PM
    Abeyancer
    Jimmie
    PNW
    Yea I can move them (with force) by hand so figured they weren't siezed. Plus they're only about 3k old.
    But I did buy a cheap A1auto kit so it's possible they're junk from the get go
