  1. Dec 25, 2021 at 8:56 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    That bumper. You could cut it down and make 2 bumpers out of it.
    Saw this beauty at work today. IG is @snowboundt4r
    CS_AR and eon_blue[QUOTED] like this.
  2. Dec 25, 2021 at 8:58 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Perfect, fatty tires look good on a runner
    CS_AR and Tour991[QUOTED] like this.
  3. Dec 25, 2021 at 9:59 PM
    Running Board Man
    Running Board Man Well-Known Member
  4. Dec 25, 2021 at 10:51 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    I've seen a quite a few with manuals around here, but yeah.. figure 7-9k for OK condition and 12k+ for something nice, and most have been over 200k miles.
    Some links for you to comparison shop against...
    Looks decent, but high mileage and needs needs some work: https://denver.craigslist.org/cto/d/denver-1996-toyota-4runner/7424184552.html
    Looks kinda thrashed and probably needs more work than the seller is letting on: https://denver.craigslist.org/cto/d/denver-1998-toyota-4runner/7422066110.html
    Looks overlanded. Up to you whether that's a pro or con: https://denver.craigslist.org/cto/d/denver-runner-sr5-for-sale/7418017705.html
    Listing has been up for suspiciously long: https://denver.craigslist.org/cto/d/aurora-1998-toyota-4runner-sr5/7415255712.html
  5. Dec 25, 2021 at 10:59 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Getting rid of the taco?
    Dibs on blower. I ever have stock parts for you
  6. Dec 25, 2021 at 11:22 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Dan, tell me why you need two blowers. Don't you have a brand new one collecting dust - much like your truck?
    04Pre_Runner likes this.
  7. Dec 25, 2021 at 11:38 PM
    Empty_Lord
    Dan
    I would have 3.
    but no. It would be a gift for my father. He’s wanted one since he sold the supercharged 3rz taco almost 2 decades ago.
  8. Dec 26, 2021 at 3:57 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
  9. Dec 26, 2021 at 4:12 AM
    CS_AR
    I go back and look at this picture from Ouray CO about once a month.
    jubei, Das it mang and Taco critter like this.
  10. Dec 26, 2021 at 8:26 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    morning all
    need to jack up the truck today and check balljoints, thinking next to buy moog upper n lowers for 150 and finally lifting it. its either that, or do rear shocks and reseal the rear diff after getting er welded.
    Truck is miles better with new fluid and shifter seat tho. no play in gears and cleaner shifts. :bananadance: lots to do
    0xDEADBEEF, CS_AR and 04Pre_Runner like this.
  11. Dec 26, 2021 at 8:34 AM
    eon_blue
    Azusa, CA
    Maybe eventually. But I need to get the alignment issue fixed before I consider selling it or else I'll have to take a big hit on it. Also would need to find something to replace it first because I can't be without a DD
    Running Board Man and CS_AR like this.
  12. Dec 26, 2021 at 8:35 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    oh and those washers for the trans bolts were like rubber. melted when i backed em out using the impact, then the new drain washer kind of started squishing while i was using the socket to put it back in. went slow but wanted to snug. Sooooo glad i got a new set to put on and will use new as well on the next service in 50 k miles.
    There was no real shavings either, just the inside of the drain bolt had lil in it with dark goopy fluid. no clue on the age of the fluid but i put on 50 k myself
  13. Dec 26, 2021 at 8:43 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Man
    the beermosas went down waaaay to good yesterday
    CS_AR and Kwikvette like this.
  14. Dec 26, 2021 at 8:44 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Let me know when you need a hand with that supercharger.
    Dan may have been asking for a long time, but he'll just let it die on a shelf. :burp:
    eon_blue[QUOTED] likes this.
  15. Dec 26, 2021 at 8:47 AM
    CS_AR
    Debating whether to order a new AC Clutch kit from McGeorge for $118 and return the $30 NSK bearing that I ordered from Amazon.
    Another idea would be to order a new Denso compressor from Rock for roughly $290. Take the clutch kit off the new compressor and use it. Save the new compressor for a later date like the next timing belt job and then replace it or if the compressor should experience problems, I would already have a new compressor in the box.
    Since I don't have a press, it will cost between $60 to $100 to get a new bearing pressed in around here. The last time I had Tacoma wheel bearings pressed into the knuckle it was $100 a pop.
    The C part of a parts store press kit will not reach across the clutch body. I unsuccessfully tried that this morning.
  16. Dec 26, 2021 at 9:20 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :spending::spending::spending:
    04Pre_Runner and CS_AR[QUOTED] like this.
  17. Dec 26, 2021 at 9:42 AM
    CS_AR
    As always. It's only money.
  18. Dec 26, 2021 at 9:45 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tell me about it.
    Getting some menudo and barbacoa since we just left Home Depot.
    Yesterday morning we found the water heater leaking; since everything was closed we couldn't replace it yesterday.
    Coincidentally, I was invited to go wheeling which I haven't done since Sept.
    Decided I'll help my FIL with the water heater instead :burp:
  19. Dec 26, 2021 at 9:52 AM
    CS_AR
    I think I will sell the 99 Maxima in the coming months. Nobody drives it. The kids don't care if I sell it. I have a new CV axle stashed away. It may have a leaking Koni shock that came with a lifetime warranty. I can clean it up and maybe find some kid that would like it. I wish my son would take it up in the northwest part of the state and sell it. Though he doesn't have time to mess with it. I would say it was my 2nd best build with the 99 Taco being the best. I think we've had it near 10 years. It is a rare little car if somebody is into this sort of thing.
  20. Dec 26, 2021 at 10:01 AM
    Speedytech7
    I'm into that sort of thing, what's the going rate on such a car? I have that headunit in the LC, it has been great.
