  1. Jan 12, 2022 at 11:53 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  2. Jan 12, 2022 at 11:53 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Should I make another pass at it on top, grind it a little first, or just leave it? 2nd side I'll do tonight trying to tighten up my range
  3. Jan 12, 2022 at 11:55 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You can try and clean it up and run a top and bottom pass to tie it, but I'd only do that if you're sure it will be better than what you ground off. I doubt it'll fall off as is, just wouldn't trust it to save your life, or not kill you in an impact by breaking off.
    treyus30[QUOTED] likes this.
  4. Jan 12, 2022 at 11:57 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Is that something I should try to do with on the other side? Like an inverted triangle with 3 passes?
  5. Jan 12, 2022 at 11:59 AM
    Speedytech7
    If I was welding them, I'd do what @Kwikvette said and grind a groove into the bottom of the tube for the root weld. That alone should be enough, but if you're not confident in it then Id do one on top of your weld and on the bottom, like an inverted triangle.
    Kwikvette and treyus30[QUOTED] like this.
  6. Jan 12, 2022 at 12:02 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Sounds good, will report back later tonight!
    Thanks guys!
    Kwikvette likes this.
  7. Jan 12, 2022 at 12:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I would've mentioned grinding again but you said you had trouble getting in there.
    Got access to a die grinder at least? Could take awhile but it'll get in there where it's tight.
  8. Jan 12, 2022 at 12:11 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I can probably get to the outer half, but not sure it's really worth it still.
    I do have a pneumatic die grinder but my bits are kinda crappy, doubt they'll make it far.
  9. Jan 12, 2022 at 12:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Or you can give up on it; there's a shitbox anonymous club going on here with @Empty_Lord being the president. Just ask him how you can join :burp:
    treyus30[QUOTED] and Wulf like this.
  10. Jan 12, 2022 at 12:27 PM
    Wulf
    rock raisin
    sometimes good enough is
  11. Jan 12, 2022 at 12:28 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    out of sight, out of mind
  12. Jan 12, 2022 at 12:50 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  13. Jan 12, 2022 at 12:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  14. Jan 12, 2022 at 12:57 PM
    Wulf
    rock raisin
  15. Jan 12, 2022 at 1:05 PM
    eon_blue
    Azusa, CA
    that's a quality Family Shitbox
  16. Jan 12, 2022 at 1:16 PM
    Wulf
    rock raisin
    breakdowns are a learning experience
    teach em to walk early
  17. Jan 12, 2022 at 1:21 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    @Kwikvette I talked to my automotive engineer buddy again today and told him about your switch panel situation. He said he's not surprised--it's likely that the door panel was subcontracted out as an assembly with the standard trim going to one vendor and the Limited trim going to another. From an assembly plant's perspective it actually makes sense. The assembly plant wouldn't be mixing and matching components like you're trying to do. A vehicle would get either a Limited door panel or a regular door panel. That's only two part numbers for the assembly plant to keep track of rather than potentially dozens of individual components.
    I wonder if you could trace the door's wiring back to a common connector that's the same on the Limited and standard trims, or if the entire vehicle wiring harness is different? There are enough extra gadgets on a Limited that it wouldn't surprise me if it got a bespoke harness.
    Obviously that doesn't help your situation but it's interesting to know.
  18. Jan 12, 2022 at 1:22 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  19. Jan 12, 2022 at 1:23 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  20. Jan 12, 2022 at 1:24 PM
    Wulf
    rock raisin
