  1. Jan 15, 2022 at 7:39 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    unstpible likes this.
  2. Jan 15, 2022 at 7:53 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  3. Jan 15, 2022 at 7:55 PM
    CS_AR
  4. Jan 15, 2022 at 9:27 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It already looks like an offbrand 90s f-150, you put that terminator grille on it and it looks like a f-150 Tijuana special
  5. Jan 15, 2022 at 9:31 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Ouch
    Good thing it’s better than an f1shitty
    04Pre_Runner and unstpible like this.
  6. Jan 15, 2022 at 11:04 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Drove the 04 for a bit this evening. Had the transmission drained to take the tcase adapter off so naturally I spent a long time screwing around with the ATF fluid level. Front driveshaft output seal on the tcase has died after my mild rebuild so that will be fun.
    Then I bedded in the new rotors/pads and just drove around waiting for things to cool off before coming back into town.
    Glad I installed @turbodb Tundra caliper hardline kit because otherwise I wouldn’t have noticed the brass glitter mess in my hub until I went wheeling again.
    turbodb and Kwikvette like this.
  7. Jan 15, 2022 at 11:11 PM
    CS_AR
    Pulling an all-nighter. Network stuff!
    Kwikvette and xtremewlr like this.
  8. Jan 15, 2022 at 11:26 PM
    CS_AR
  9. Jan 15, 2022 at 11:31 PM
    04Pre_Runner
    Andrew
    CS_AR[QUOTED] likes this.
  10. Jan 15, 2022 at 11:40 PM
    Empty_Lord
    Dan
    2uz has rubber sections. failure is super rare though
    CS_AR and 04Pre_Runner[QUOTED] like this.
  11. Jan 16, 2022 at 12:21 AM
    CS_AR
    I think in 4 years when mine is due for a timing belt around 280,000 miles, I'll give it a new damper pulley. It will be 27 years old then. LOL
  12. Jan 16, 2022 at 6:19 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Lol, It does look like a F150
  13. Jan 16, 2022 at 6:29 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
  14. Jan 16, 2022 at 7:06 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Too bad there isn't a Fluidamper available for the 2UZ.
    CS_AR likes this.
  15. Jan 16, 2022 at 8:04 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just send it
  16. Jan 16, 2022 at 8:38 AM
    CS_AR
    xtremewlr[QUOTED] likes this.
  17. Jan 16, 2022 at 8:42 AM
    CS_AR
    That looks like Lexus wood trim that's molded into the plastic. No removing that.
    Tour991[QUOTED] likes this.
  18. Jan 16, 2022 at 8:44 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Not a fan of the wood trim.
    Just sucks my switches aren't interchangeable, and the trim pieces won't accept the necessary switches.
    Tour991 and CS_AR[QUOTED] like this.
  19. Jan 16, 2022 at 8:52 AM
    CS_AR
    I'm in the same boat. I did switch out the center console part for one with black plastic and knobs instead of LCD displays and plastic wood.
    The rest will be with me for a while. I ended up paying around $400 for a used black plastic knob version.
    The LX switches are functionally different from the Landcruiser. All switches are automatic where the LC is only the driver's window.
  20. Jan 16, 2022 at 8:55 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's not bad; wood trim is limited to the shifter plate and steering wheel. That and the center bezel and shift plate aren't connected.
    Still looks good :thumbsup:
