  1. Feb 1, 2022 at 2:35 PM
    Wulf
    rock raisin
  2. Feb 1, 2022 at 2:52 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    :cheers: awesome news! Thanks for making the call.
  3. Feb 1, 2022 at 3:09 PM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    URD Supercharged reg cab on eBay, don't see those every day. I really like 2nd gen regs. I'd be tempted to jump on a super clean low miler if it popped up. I thought this was an AZ truck until I looked at the CF
    https://www.ebay.com/itm/265527737812
  4. Feb 1, 2022 at 3:12 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Long post inbound :D
    I think there’s a lot to that! The only real injury I’ve gotten while lifting was from doing heavy singles. I was warmed up, I felt great, and I just kept pushing. Never felt anything pop or anything, but later that night my right hip started really hurting. Now I have a pretty noticeable click in that hip and it’ll bark at me if I go too heavy too soon.
    I basically adapted a program by Dan John called Easy Strength. It’s a resistance training program that can be used with restricted calories, so the intensity is pretty moderate. You basically rotate between two exercises for each movement type: vertical push and pull, horizontal push and pull, a hip hinge movement like the deadlift, explosive movements, weighted carries, and ab work. The idea is to do 3-4 exercises every day, no more than 10 reps total, with minimal rest at a light to moderate load where you can keep your form up. Then each day after the lifting you do some steady cardio. When you feel comfortable adding a little weight, you make small jumps on an exercise by exercise basis.
    I’m just getting started, but I’m already having to reduce the weights a bit because ego. The only way to maintain it day to day is to keep the weight relatively light at first, so it definitely forces you to be humble numbers-wise so you don’t overdo it. Since my goal is to weigh less when the riding season hits, it helps with that for sure, but still keeps me lifting in some way.
    CS_AR and Wulf[QUOTED] like this.
  5. Feb 1, 2022 at 3:21 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Should I be as nervous as I am to try the on campus sushi?
    Doesn’t look scary, but it might be.
    unstpible and 04Pre_Runner like this.
  6. Feb 1, 2022 at 3:29 PM
    jubei
    NoCo
    Stuff. Also things.
    Logan is known for its fresh seafood after all
    Abeyancer, Blue92, JKO1998 and 3 others like this.
  7. Feb 1, 2022 at 3:31 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    The first time I tried sushi was at a gas station in Montana.
    jubei and unstpible like this.
  8. Feb 1, 2022 at 3:32 PM
    eon_blue
    Azusa, CA
    If it's from the gas station, or more than a day's trip from the ocean...nope
  9. Feb 1, 2022 at 3:33 PM
    eon_blue
    Azusa, CA
    You are a brave, brave man
    Food poisoning is easily one of the worst physical ailments I've ever been through, at least one of them was.
    unstpible likes this.
  10. Feb 1, 2022 at 3:35 PM
    eon_blue
    Azusa, CA
    I'd dip that stuff in isopropyl alcohol first
  11. Feb 1, 2022 at 3:37 PM
    JKO1998
    Utah
  12. Feb 1, 2022 at 3:42 PM
    JKO1998
    Utah
  13. Feb 1, 2022 at 3:44 PM
    01x4
    jubei likes this.
  14. Feb 1, 2022 at 3:45 PM
    eon_blue
    Azusa, CA
    Nothing wasabi afterward can't fix
    High Noon likes this.
  15. Feb 1, 2022 at 3:51 PM
    JKO1998
    Utah
    Spent some money on the expo today :anonymous:
  16. Feb 1, 2022 at 3:51 PM
    JKO1998
    Utah
    Shit posts
  17. Feb 1, 2022 at 3:53 PM
    Wulf
    rock raisin
    i imagine you've eaten enough gas station food to have the fortitude for it :luvya:
  18. Feb 1, 2022 at 3:54 PM
    JKO1998
    Utah
    Why not
  19. Feb 1, 2022 at 3:54 PM
    eon_blue
    Azusa, CA
    I've only gotten food poisoning twice...once at a hole in the wall Mexican restaurant out in the desert (friends and I went in right before closing, I have a feeling it was retribution), and another time while in Nicaragua. I either broke the "don't drink the water" rule or it was something I ate, but that was by far the worst one. Plus, feeling deathly ill in another country and all
    I was eating Immodium by the handful and it was doing absolutely nothing lol. 4 days of puking out of every orifice every 5 minutes, night & day
  20. Feb 1, 2022 at 3:56 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Yup. Shrimp Tacos in Arkansas was not a good idea.
    CS_AR and eon_blue[QUOTED] like this.
