  1. Feb 12, 2022 at 10:14 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
  2. Feb 12, 2022 at 10:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  3. Feb 12, 2022 at 10:20 PM
    Empty_Lord
    Dan
    indeed
    what road and Kwikvette[QUOTED] like this.
  4. Feb 12, 2022 at 10:37 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  5. Feb 12, 2022 at 10:58 PM
    Running Board Man
    Running Board Man Well-Known Member
    Easy peasy it replaced the slider gears, no lash or preload to check because you don't touch that
  6. Feb 12, 2022 at 11:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah I'll need to look underneath cause I guess pulling the 3rd will require a bit more work.
    Having a full float rear end means no diff cover.
  7. Feb 12, 2022 at 11:37 PM
    Speedytech7
    Did the previous owner save the spider gears for you. If not you'll probably need another carrier or at least some replacement spider gears and the appropriate shims
  8. Feb 13, 2022 at 12:40 AM
    Empty_Lord
    Dan
  9. Feb 13, 2022 at 12:45 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  10. Feb 13, 2022 at 5:47 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  11. Feb 13, 2022 at 6:08 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    A FB discussion got me started. Sometimes I miss New Jersey Sunday Mornings.
    Pastelillos de Guayaba
    with Café con Leche.
    Wulf, Area51Runner, jubei and 2 others like this.
  12. Feb 13, 2022 at 6:44 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    The Uniden CB showing up in the "Products Discussed in This Thread" has had a 16% price drop, if someone was considering buying on. It's down to $58.00.
    tcBob and Running Board Man like this.
  13. Feb 13, 2022 at 8:03 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Paid $53.32 according to my past order.
    Then again, $5 is $5
  14. Feb 13, 2022 at 8:12 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  15. Feb 13, 2022 at 8:19 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  16. Feb 13, 2022 at 8:47 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    The footer shows $79.98 when Amazon shows $58.66 and an Amazon price tracker shows the highest it's been in the past year is $69.99?
    Wsidr1[QUOTED] and CS_AR like this.
  17. Feb 13, 2022 at 8:59 AM
    CS_AR
    Sperrunner[QUOTED] likes this.
  18. Feb 13, 2022 at 10:05 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    The Spartan replaces the factory spider gears and cross pin in theopen diff carrier.
    You could replace the Spartan with spider gears to go back to open diff again, but a full selectable replaces the open carrier and the backlash will probably need to be adjusted
  19. Feb 13, 2022 at 10:15 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
  20. Feb 13, 2022 at 10:21 AM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Think I'm going to grab this Amp'd Up skid for my 99. I don't have the fab skills to make my own and it's cheaper than a BudBuilt. I've slapped my front diff on rocks like 6 times now so it's necessary. Then I'll weld a new front crossmember between the frame rails since it was ripped off my truck from accidents.
