  1. Sep 30, 2018 at 5:08 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    the fuck if you cant
    Crodell6 likes this.
  2. Sep 30, 2018 at 5:09 PM
    JKO1998
    Utah
    Im attempting to write an essay about shark fishing.
  3. Sep 30, 2018 at 5:26 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    15383534873212138043641.jpg ok, I need to know the size of the screw that holds the handle for the seat ?
  4. Sep 30, 2018 at 5:28 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    15383536260951856065557.jpg this is the driver side. Wife lost the passenger one
  5. Sep 30, 2018 at 5:28 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    should be the same screw as what holds the dash face on.. pull one out and match it.
  6. Sep 30, 2018 at 5:38 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Well my di-why intake cleaning did okay but I'd rather just take these nasty ass parts to a machine shop with a hot tank. @mechanicjon You know a good machine shop in PHX?
    BartMaster1234 likes this.
  7. Sep 30, 2018 at 5:47 PM
    Empty_Lord
    Dan
    To rebuild this diff or sell... tis the question
  8. Sep 30, 2018 at 5:49 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Slightly larger self tapping sheet metal screw and an impact drive size.
    lucky13don[QUOTED] likes this.
  9. Sep 30, 2018 at 6:21 PM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    Are manual hubs better for more than 2 inches of lift? Just read it here
    Running Board Man likes this.
  10. Sep 30, 2018 at 6:26 PM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    Any of you cali guys getting rain? Az is feeling nice, lots of clouds
  11. Sep 30, 2018 at 6:31 PM
    Empty_Lord
    Dan
    well they dont spin when theyre disengaged soo theyre better if your in 2wd all the time.. but you still will run into issues if you use 4wd alot. (more of an issue the closer you get to 3")
  12. Sep 30, 2018 at 6:33 PM
    JKO1998
    Utah
    TThousands of people run Auto hubs, sure they spin all the time, but still, most don’t have a problem.
  13. Sep 30, 2018 at 6:35 PM
    Speedytech7
    It's rainy in Mesa now
  14. Sep 30, 2018 at 6:36 PM
    JKO1998
    Utah
    It’ll hit Utah Monday, we got a bit of wind today.
    tymeson[QUOTED] likes this.
  15. Sep 30, 2018 at 6:39 PM
    Speedytech7
    They break boots less often cause they don't turn 100% of the time. But they're weaker too sooo
    tymeson[QUOTED] and JKO1998 like this.
  16. Sep 30, 2018 at 6:46 PM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    I'm just indecisive on what I should do for the conversion. ADD vs Manual
  17. Sep 30, 2018 at 6:46 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    I need to bail out rainwater of my 4wd bed lol.... I got both shifters taken out in anticipation of my clutch coming in.
    Running Board Man and tymeson like this.
  18. Sep 30, 2018 at 6:49 PM
    Speedytech7
    ADD will be tougher to do but if you find an add system from 01-04 I can help you wire it up. Manual hub is a lot easier and if you don't plan to go to tires bigger than 33 will be more than fine, even for 35 it would be okay.
  19. Sep 30, 2018 at 6:53 PM
    Sebz13
    Shane
    Maui Hawaii
    also got my 3/4 dropped 03 std cab all solid now. Changed out;
    Upper/Lower Ball joints, OEM
    New lower control arm
    New DJM bushings and washers and nuts
    New DJM shocks all around
    New bushing kit and stabilizer bushings
    Tie rod ends
    SS brake lines
    Power Stop Calipers
    Power stop slotted rotors
    Akebono Pads
    New wheel bearings inner and outer
    new races.
    Truck drives like it came the day I bought it, I'm so elated. I got it up to 100 the other day and it didn't feel like it was gonna die. Got it aligned and tires rotated. I saw the tech about to pound on my lugs and I ran in the bay and made him torque them by hand all to 85 ft/lb Ahahaha.
    ireymon likes this.
  20. Sep 30, 2018 at 6:56 PM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    Alright, I might as well do ADD if I can get some help. I wanted to do manual just because it was going to be easier on me.
    It just started raining.
