  1. Jun 26, 2018 at 9:37 PM
    #3741
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Does the axle sit near the very top of the wheel hub? That's different.
  2. Jun 26, 2018 at 9:38 PM
    #3742
    JKO1998
    JKO1998 Well-Known Member
    Utah
  3. Jun 26, 2018 at 9:39 PM
    #3743
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    So the axel shaft goes into the top of a portal then gears drive a shaft thats lower down which you mount the hub to so you get more gear reduction as well as ground clearnce
  4. Jun 26, 2018 at 9:39 PM
    #3744
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Those are gearboxes bolted on...
  5. Jun 26, 2018 at 9:40 PM
    #3745
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Thanks, I'll check it out.
  6. Jun 26, 2018 at 9:40 PM
    #3746
    eon_blue
    Azusa, CA
    Sperrunner likes this.
  7. Jun 26, 2018 at 9:40 PM
    #3747
    BartMaster1234
    Tyler
    Flux Capacitor
    Huh. That's different.
  8. Jun 26, 2018 at 9:41 PM
    #3748
    JKO1998
    Utah
    I think it’d be fun to cruise around in haha, maybe not with those wheels and tires though.
  9. Jun 26, 2018 at 9:42 PM
    #3749
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    https://youtu.be/jderNuCCpLU
    Its a really expensive set up but gives great gear ratio for crawling. Some military trucks have them like hummers
  10. Jun 26, 2018 at 9:42 PM
    #3750
    Speedytech7
    93-97 Land Cruiser FZJ80 or Lexus LX450. Just have to confirm they have the locker switch...
    Area51Runner likes this.
  11. Jun 26, 2018 at 9:42 PM
    #3751
    Speedytech7
    Some of the FJ62s have them too but it is very hit and miss
  12. Jun 26, 2018 at 9:43 PM
    #3752
    BartMaster1234
    Tyler
    Flux Capacitor
    Christ that's excessive.
    My buddy with an H1 showed me how you change the brake rotor, which is conveniently located behind the wheel. I think it has the same axle as that YouTube video.
  13. Jun 26, 2018 at 9:43 PM
    #3753
    JKO1998
    Utah
    They don’t take pictures like that on KSL haha.
    Thanks
  14. Jun 26, 2018 at 9:46 PM
    #3754
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    If you watch DED he put portals on his alabama army truck
  15. Jun 26, 2018 at 9:46 PM
    #3755
    Speedytech7
    Should see how early Toyota pickups and most land cruisers do rotors. Have to basically take the hub and bearings off to do them and the hub is bolted separately to the rotor.
  16. Jun 26, 2018 at 9:47 PM
    #3756
    BartMaster1234
    Tyler
    Flux Capacitor
    The 5-lug is the same way. You have to take the hub and bearing off for some reason.
  17. Jun 26, 2018 at 9:48 PM
    #3757
    Speedytech7
    Plus side is bearings are dead simple, might as well do em with your brakes. Just have to learn the trick to setting your preload... And have a 54mm socket haha
  18. Jun 26, 2018 at 9:49 PM
    #3758
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yeah its a big pita to do a rotor change
    Ik ive done it
  19. Jun 26, 2018 at 9:49 PM
    #3759
    JKO1998
    Utah
  20. Jun 26, 2018 at 9:50 PM
    #3760
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    The hub nut has like 12ft lb of touqre in them on 5lugs lol
