  1. Apr 5, 2022 at 10:36 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Or just not have to worry about it
  2. Apr 5, 2022 at 10:36 AM
    eon_blue
    Azusa, CA
    but you keep asking about boost
    or are you just feeding your fantasy
  3. Apr 5, 2022 at 10:37 AM
    Wulf
    rock raisin
    Future faking moment
    Abeyancer and eon_blue[QUOTED] like this.
  4. Apr 5, 2022 at 10:37 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  5. Apr 5, 2022 at 10:38 AM
    JKO1998
    Utah
    Feeding fantasy
    eon_blue[QUOTED] likes this.
  6. Apr 5, 2022 at 10:40 AM
    eon_blue
    Azusa, CA
    it's not all it's cracked up to be tbh
    maybe it is with the Haltech, probably
    Abeyancer and Wulf like this.
  7. Apr 5, 2022 at 10:48 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    If you went that route, yes you are correct, several bottles would need to be added (depending on brand) or "make your own" by buying race fuel like this
    apihqneqa__65969.1640799778.png and then just add a portion to your regular to make "premium" I don't remember the ratio but it's what I used to do with my racing mowers.
    It's all that happens at a gas station.. there's no such thing as mid grade. They only deliver regular and premium and then pull from both tanks to sell you mid grade
  8. Apr 5, 2022 at 10:49 AM
    Abeyancer
    Jimmie
    PNW
    But the hursepwrs gains bro!
  9. Apr 5, 2022 at 10:49 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    We can get race fuel at the pump here, we have 100 and 110 leaded and E85.
    Abeyancer[QUOTED] likes this.
  10. Apr 5, 2022 at 10:50 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    4Runners had the geadhasket issue and it’s still pretty rare
  11. Apr 5, 2022 at 10:50 AM
    Empty_Lord
    Dan
    That’s how my gas station down the road is. Even leaded is on tap
  12. Apr 5, 2022 at 10:51 AM
    JKO1998
    Utah
    I think youre a little wrong here but not gonna push it
  13. Apr 5, 2022 at 10:51 AM
    Speedytech7
    Can also get 91 Ethanol free 93 E10 and regular 87 of course
  14. Apr 5, 2022 at 10:52 AM
    Speedytech7
    05-08 4.0 2nd gens had poop HGs (may not be recognized as a TSB or whatever but they fail regularly if they're still originals) and motor mounts perches
  15. Apr 5, 2022 at 10:55 AM
    eon_blue
    Azusa, CA
    We have a station like that near my work, last I saw a year or so ago it was around $10 for 108 octane. Wonder what it is now lol
  16. Apr 5, 2022 at 10:55 AM
    Toyotadilly
    Toyotadilly Well-Known Member
    Dillynn
    Sarasota,fl
    03 prerunner 2008 Toyota Sequoia limited w/tow package..01 echo 310k soon daily
    Bilstein 5100’s.eibach coils.stoptech cryogenic rotors.1.25in toytec blocks.tranmission cooler. Electric fan w/ relay.
    No spacers. I got the trusted 5100s with eibach coils. Just trying to properly limit everything
  17. Apr 5, 2022 at 10:56 AM
    Speedytech7
    Stock bumps will properly limit that, I ran the same setup early on. You could get duro bumps, youll hit them sooner but they're progressive so they get harder the more you get into em
  18. Apr 5, 2022 at 10:57 AM
    Abeyancer
    Jimmie
    PNW
    That's Ballin da most status there! There's a gas station here near the drag strip track that sells 110 105 and 100 but when I was in bumfuck nowhere PA I had to special order those 5 gal metal cans of 110 for my race mowers lol
  19. Apr 5, 2022 at 11:02 AM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    The head gasket talk has reminded me. What are the chances that my truck running a mix of Dexcool/Toyota SLL Pink for 5000 miles did damage to my 04 head gasket?
    When I bought the truck in high school the water pump was slow leaking. So my father chose to fill the empty reservoir with GM Dexcool. I had the timing belt and water pump done after the next oil change and had the truck flushed with Prestone green. Then converted back to Toyota SLL Pink ~10,000 miles after that.
    I know 01-04 head gaskets are supposed to be improved. So I assume it’s just poor luck.
  20. Apr 5, 2022 at 11:04 AM
    Speedytech7
    It's low, 01-04 HGs are MLS. They're pretty damn good but corrosion will kill them. 5000mi won't make or break anything if it was less than 2 years
    04Pre_Runner[QUOTED] likes this.
