  1. Apr 5, 2022 at 12:26 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    It concentrates the force on a smaller area, it’ll probably just break the bolt off, but still.
    and the angle of impact is probably all sorts of wonky now
  2. Apr 5, 2022 at 12:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :rofl:
    Good ol' LT always delivers
    Abeyancer and Das it mang like this.
  3. Apr 5, 2022 at 12:31 PM
    Wulf
    rock raisin
    why do people believe in psychics?
    Das it mang, 0xDEADBEEF and xtremewlr like this.
  4. Apr 5, 2022 at 12:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Yota X
    Cut those pieces from those blueprints
    Bent some flat bar for the legs, and drilled/tapped the bracket that goes onto the side. Also welded that flat stock inside one of those square tubes then mocked it up.
    Not a huge fan of multiprocessors but w.e.
    I welded the longer extension to it as shown in the mock up, just didn't get a picture as I was leaving.
    Should be finishing it tomorrow.
    The part that takes up time is sharing the press brake, or grinding out those damn notches in the fire grates. At least the tapped hole came out perfect.
    Yota X and Das it mang like this.
  5. Apr 5, 2022 at 12:31 PM
    JKO1998
    Utah
    So they have something to blame
    Das it mang and Wulf[QUOTED] like this.
  6. Apr 5, 2022 at 12:32 PM
    Running Board Man
    Running Board Man Well-Known Member
    you realize the welded nut on the inside of the control arm only ever breaks off when the bump stop is loose right?
    The bumpstop being tight pulls the nut toward the control arm and any force applied by the bunpstop is applied to the control arm and not the nut
    That nut is only there to hold it in place not transfer any energy is the message I meant to send with that
    Hence why you can have that but break off inside and still have the bumpstop do it's job
  7. Apr 5, 2022 at 12:33 PM
    eon_blue
    Azusa, CA
    same reason they believe in religion I guess, it provides answers accepted solely on the basis of faith
    Das it mang likes this.
  8. Apr 5, 2022 at 12:35 PM
    JKO1998
    Utah
    Either way, you’re putting more energy onto a smaller already.
    LCA’s already have problems
  9. Apr 5, 2022 at 12:35 PM
    Running Board Man
    How much are you looking to pay for my solos assuming you're serious
  10. Apr 5, 2022 at 12:37 PM
    JKO1998
    Utah
    How bad are you wanting to sell them
  11. Apr 5, 2022 at 12:38 PM
    Wulf
    rock raisin
    you can see a tarot reading but you can't see bump stop physics :thinkin:
    Das it mang and eon_blue[QUOTED] like this.
  12. Apr 5, 2022 at 12:38 PM
    Running Board Man
    I want to get rid of the truck but I got it for 1600 bucks and I know the ~1200 dollar lower control arms and ~500 uppers don't add value to such a shitbox
    Would you be interested in a package deal for spcs and solos?
  13. Apr 5, 2022 at 12:39 PM
    JKO1998
    Utah
    Probably
  14. Apr 5, 2022 at 12:40 PM
    Running Board Man
    What do you think about 1500 for all 4 they were all really only ever daily used because Texas specifically my part of Texas is a flat wasteland
  15. Apr 5, 2022 at 12:41 PM
    JKO1998
    Utah
    Sus
    https://www.instagram.com/p/B8NkUeGg3H9/
    04Pre_Runner, eon_blue and Kwikvette like this.
  16. Apr 5, 2022 at 12:46 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    my brother is a saint: change of clothes, brake cleaner, his jack and some spare tools. Guess i earned it helping him do the fuel pump on his dodge lmaoo
    Abeyancer, 04Pre_Runner and Wulf like this.
  17. Apr 5, 2022 at 12:46 PM
    Running Board Man
    I guarantee you the x-axis bushings have zero play and are still tight
    The ball joints felt loose out the box so I can't say they're tight but they don't have any play and have always been over greased
    A shop hit something in my truck on a test drive after an alignment and dinged the frame to where it's pushed in about 1/16 of an inch it chafing one of the bushings on the lcas but won't cause a problem
  18. Apr 5, 2022 at 12:47 PM
    JKO1998
    Utah
    I’ll give you 1000 and shipping
  19. Apr 5, 2022 at 12:48 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    same reason my ex believed in horoscopes, tarot card readings, etc. Like jaxon said it gives them a means to blame or project, have excuses, etc
    Kwikvette likes this.
  20. Apr 5, 2022 at 12:49 PM
    Running Board Man
    Can you do 1150
