  1. Apr 20, 2022 at 6:17 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Right
    at my shoulder?
  2. Apr 20, 2022 at 6:20 PM
    Wulf
    rock raisin
    Guess I should have asked Upper shoulder or lower shoulder lol
  3. Apr 20, 2022 at 6:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Stud finder, finding studs
  4. Apr 20, 2022 at 6:32 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    Super necessary!!
    Kwikvette[QUOTED] likes this.
  5. Apr 20, 2022 at 6:41 PM
    Yota X
    NW New Jersey
    1st gen
    @Wulf
    How the fuck do you get a pitman arm off a gear? I used freeze off and my pullers. Broke one puller. Then hit it with the map gas and it still won't come off. I got it half way and its stuck! Can't fit it in press. I don't want to cut off and have to file splines. Kinda pissed me off.
    Wulf likes this.
  6. Apr 20, 2022 at 7:17 PM
    Running Board Man
    Running Board Man Well-Known Member
    Guy said it uses a titan hub bearing
    You could probably get something going with a custom cv
  7. Apr 20, 2022 at 7:18 PM
    Wulf
    rock raisin
    That's pretty much it. Is it rusty?
    You can put it under tension with the puller, heat, and whack it on the side and hope it pops off
    jubei and Yota X[QUOTED] like this.
  8. Apr 20, 2022 at 7:20 PM
    Wulf
    rock raisin
    Fuel pump on the Ford is pissing me off. Shop says it's a normal amount of noisy but I'm not happy.
    Took the lower filter off and cleaned the fuck out of the housing, threads, o ring for the 3rd or 4th time since I bought the truck before I greased the o ring, and put it together and it's quieter but still sounds like a kazoo
  9. Apr 20, 2022 at 7:23 PM
    Yota X
    NW New Jersey
    1st gen
    Ok. The shaft is a little rusty but nothing crazy. I tried doing all that. I gave up so I could start fitting it in truck. Ill prob just weld some nuts to it so I can pull it better. Just thought there may have been a secret move on that fucker. lol Thanks!
  10. Apr 20, 2022 at 7:26 PM
    Wulf
    rock raisin
    It is a bitch if it's been on there any amount of time lol
    Can't remember if they're hardened or not, but you can try and make a vertical cut (parallel with the splines) through it with the grinder to relieve some tension or completely cut it off
    Yota X[QUOTED] likes this.
  11. Apr 20, 2022 at 7:26 PM
    Wulf
    rock raisin
    dad mode
  12. Apr 20, 2022 at 7:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I love telling dad jokes
    sometimes he laughs :laughing:
    Abeyancer and Wulf[QUOTED] like this.
  13. Apr 20, 2022 at 7:31 PM
    Yota X
    NW New Jersey
    1st gen
    I got it shipped from a junk yard. Its prob been on their shelf for a decade. But for $75 ill deal with it.
    Wulf[QUOTED] likes this.
  14. Apr 20, 2022 at 7:35 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I gave that a thought for a minute and no doubt I could have an axle shaft made although that would be a replacement parts nightmare. Real issue is the spindle isn't designed for a pass through, it's got a solid back, and the shock is dead center where the CV would need to go.
  15. Apr 20, 2022 at 7:37 PM
    Wulf
    rock raisin
    Time to build the birfield centipede
    Abeyancer and Running Board Man like this.
  16. Apr 20, 2022 at 7:39 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    @01x4 new rack came in
    CS_AR, 01x4, 0xDEADBEEF and 3 others like this.
  17. Apr 20, 2022 at 7:44 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Dad jokes and not even a dad yet :luvya:
  18. Apr 20, 2022 at 7:48 PM
    JKO1998
    Utah
    Blue tooth cv axle
    Running Board Man and Kwikvette like this.
  19. Apr 20, 2022 at 8:03 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Huh. I guess my terminator post was just too much for the pic thread. Or the forum is messing up
  20. Apr 20, 2022 at 8:15 PM
    Yota X
    NW New Jersey
    1st gen
    How much was that thing?
