  1. May 21, 2022 at 8:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah definitely don't want more than 2 hoods :rofl:
  2. May 21, 2022 at 9:00 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I think there's three in my shop, two of mine in my buddies shop, and one passive shield in the truck for trail repairs.
  3. May 21, 2022 at 9:02 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Let me be honest though, I cant even remember the last time I had to weld at home. Been a few years.
    Probably oughta sell the shit and reinvest the dough into another hobby.
  4. May 21, 2022 at 9:03 PM
    Running Board Man
    Running Board Man Well-Known Member
    I've run nothing bit Flux core at my house... and I hate it
  5. May 21, 2022 at 9:04 PM
    Speedytech7
    I dunno what size my old garage was but it was plenty easy keeping it safe enough to weld and it was packed full. Fuel got stored outside in a deck box and chemicals were on a shelf that got covered with a welding blanket. Grinder sparks were shot everywhere in that place too. Now all I use the blanket for is myself so I don't get burnt all over, it is fairly easy to keep everything away now since I only put one vehicle in at a time for work.
    Running Board Man likes this.
  6. May 21, 2022 at 9:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I really want a welding setup I can carry with me, well really just a stinger and ground cable with clips to attach to a battery @Abeyancer
    Not that I'd need to perform such a repair often, but it'd be small/light enough to just leave in the Land Cruiser.
  7. May 21, 2022 at 9:05 PM
    Speedytech7
    I just carry a cable set and a pack of 6013.
    Kwikvette[QUOTED] likes this.
  8. May 21, 2022 at 9:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I should do that, though my choice would be 7018 rod.
  9. May 21, 2022 at 9:07 PM
    Running Board Man
    I shudder at the welds I made on my camry subframe... welding through literal grease than having liquid rubber pour into the weld as I'm going than stopping and starting to put the fire out... disgusting
    but it's a wrecked 96 camry... as long as it's one piece
  10. May 21, 2022 at 9:09 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Forgot about the one corner that had the hand loading bench setup so add gun powder to the mix haha. It wouldve been too much work to keep everything safe enough to weld in there since it was my dads place and he wanted it setup the way he wanted. Also between him and seeing a few industrial accidents firsthand I guess I have more of a safety mindset than some. My house just has the carport and Id be fine welding stuff up in there but like I said, I really have no need to anymore.
  11. May 21, 2022 at 9:10 PM
    Speedytech7
    Flux core loves garbage falling into it haha, why else would it always look the same :rofl:
  12. May 21, 2022 at 9:11 PM
    Speedytech7
    Okay that last one is actually a fair excuse. I'm not welding near open powders and shit. A single spark actually will do something to that, at least it would be over quick.
  13. May 21, 2022 at 9:13 PM
    Chungas
    Chungas Help! My Ferret has lost its stank!
    Waylon
    Bushwood CC
    Cocain 2003 3.4 4x4
    Any of you know how to get a wheel off that has two spun lug studs?
  14. May 21, 2022 at 9:15 PM
    Running Board Man
    Cut a slit in it with a angle grinder with a cutoff wheel than split the nut with a chizzel
    unstpible and Taco critter like this.
  15. May 21, 2022 at 9:16 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    So sorry to hear. She was a special one.
  16. May 21, 2022 at 9:18 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    You just reminded me I need to research fire extinguishers for the new place. I have a fire extinguisher mounted in both trucks now. Need to get some in the house and garage. Old rental house had them mounted already.
  17. May 21, 2022 at 9:19 PM
    Running Board Man
    Are you renting still?
  18. May 21, 2022 at 9:20 PM
    04Pre_Runner
    Andrew
    Yup. Not in the position to buy unfortunately. Situation is better now though.
  19. May 21, 2022 at 9:21 PM
    Chungas
    Waylon
    Bushwood CC
    Cocain 2003 3.4 4x4
    Without trashing the wheel?
  20. May 21, 2022 at 9:22 PM
    Speedytech7
    You might have luck pulling the nuts that will come off and then yanking the wheel outward to put tension on the spun studs while trying to work the nuts off.
