  1. Jul 3, 2022 at 2:20 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    100% metal as far as I could tell. I didn't notice any marking at all on the spring. It was an easy bend with a pair of forceps to the straight not coiled portion of the spring. Just enough to put the RPM's where my ear said they should be. I know I'm running it higher then factory but the motor sounds good and strong. For now.
    Honestly, it's lived a good life and returning it to "normal" RPM's isn't a concern. When it goes it goes. I'm also the kinda guy that runs the 3.4L motor into the 4K range all the time. lol
    Abeyancer[QUOTED] likes this.
  2. Jul 3, 2022 at 2:39 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Oohhhh okay, sounds like you've got one of the flathead briggs.. something like a 126M02 model. The long spring you easily bent was wrapped around/alongside a metal link piece correct? So long as the metal arm is there, It won't blow up that much more prematurely. .. the fact you were able to fix it by increasing the revs tells me it was more than likely getting too much gas, seats staeting to wear out and if it starts flooding or soaking the air filter, thats why. Needle and seat rebuild kit is cheap, briggs part number 398188. All these are governed to run at 3600rpm But honestly you can run these little guys at 3.9k without risk of snapping a con rod.
    4k though, make sure you preclear your yard of sticks cause cause a sudden jolt to the crankshaft is not going to be well received lol
  3. Jul 3, 2022 at 3:08 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Any of my LT bros need these?
    unstpible, Tour991 and Wulf like this.
  4. Jul 3, 2022 at 3:34 PM
    Running Board Man
    Running Board Man Well-Known Member
    1"?
  5. Jul 3, 2022 at 3:45 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Was gonna say damn you're close, must be familiar with what 1" looks like :luvya:
    It's 1.25"
  6. Jul 3, 2022 at 3:57 PM
    eon_blue
    Azusa, CA
  7. Jul 3, 2022 at 3:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Or maybe, Gary was never really into Doris
  8. Jul 3, 2022 at 4:03 PM
    eon_blue
    Azusa, CA
    To me it looks more like Gary lost a bet with his buddies
    Or it's his birthday and he's got some lovely a-hole friends lol
  9. Jul 3, 2022 at 4:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Filling up the garage rack; found all this in storage!
    Also got these @Area51Runner if you need
    Wulf and Area51Runner like this.
  10. Jul 3, 2022 at 4:40 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Thanks bud, but I'm all set.
    Now if you have a spare drive shaft (rear front section) or an A340f sitting in storage.... :anonymous:
    unstpible and Kwikvette[QUOTED] like this.
  11. Jul 3, 2022 at 4:40 PM
    Wulf
    rock raisin
    Sperrunner[QUOTED] likes this.
  12. Jul 3, 2022 at 4:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Have a driveline shop make one for you.
    I'm sure you can but custom ones online if you ask someone in here for the length you need.
  13. Jul 3, 2022 at 4:42 PM
    Wulf
    rock raisin
    Tom Woods if you want the beef
  14. Jul 3, 2022 at 4:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Wulf
    I always forget you have manual hubs, cause I always think of your crawler and not your Tacoma.
    You need those parts?
    Ball and detent spring are for a manual hub, lock washers are for manual hub cv axles, and the bolts act as a backup cv axle retention if the lock washers fail. I normally call them snap rings but they're not exactly the same as a snap ring (though they act like one).
    Wulf likes this.
  15. Jul 3, 2022 at 4:45 PM
    theesotericone
    Bishop CA
    I got one. It's still attached to my wheeling rig which is for sale. Take the whole package. lol
  16. Jul 3, 2022 at 4:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    He doesn't even wheel tho :bananadead:
  17. Jul 3, 2022 at 4:50 PM
    theesotericone
    Bishop CA
    This.
    Their CS is on par with ECGS. About a month after I got my F/R shafts from them the rear shaft blew apart at the flange. Now, it wasn't Woods fault. I had snapped a lower link and that pulled my drivers axle WAY forward. I knew I was bound up and putting it in lo/lo would either move that axle back or something would fail. That something was the diff side flange on the new shaft.
    I called Woods and they sent an RMA immediately. It shipped out of Bishop on a Monday. I had it back in my hands that same Friday. Oh, and the invoice they sent me? An email that said it was my freebie. And they didn't just replace the flange. The gave me a brand new shaft. I didn't even pay for shipping. Yep. That's how you run a business and retain customers.
  18. Jul 3, 2022 at 4:53 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Why don't you have your old one shortened? It's cheaper and easier. Driveline Services of San Leandro only charged me around $100 with new tube welded and re-balance. Took them... 2 days.
  19. Jul 3, 2022 at 4:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    When both 4x4's stand by waiting to get new replacement parts installed :bananadead:
    (Other one in the driveway)
    unstpible, Abeyancer and Wulf like this.
  20. Jul 3, 2022 at 5:04 PM
    Wulf
    rock raisin
    Put me last on the list, I'll take em if nobody else does :D
    Abeyancer likes this.
