  1. Aug 13, 2022 at 7:30 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Are the cane variable speed? Or you just want them to stage in pairs base off temp
  2. Aug 13, 2022 at 7:31 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    The fans are capable of changing speed it’s just we don’t have any logic to do that. That’s why it’s 100% speed all the time. We want it to change on engine temp so it doesn’t kill the life span of them.
  3. Aug 13, 2022 at 7:34 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Staging would be easier. But if you could fine a temp controlled rehostat then you can probably control fans just by speed
  4. Aug 13, 2022 at 7:34 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    So all you need is a temp sensor with a discrete output signal in series before those contactors. Easy peasy.
    jubei likes this.
  5. Aug 13, 2022 at 7:46 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Interesting. Okay. Thank you.
  6. Aug 13, 2022 at 7:46 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    How would you go about staging?
  7. Aug 13, 2022 at 7:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Fuck I'm sorry to hear.
  8. Aug 13, 2022 at 7:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Thank you
  9. Aug 13, 2022 at 7:48 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Need 3 temp switches at different temps and put 2 fans per relay. So as each switch triggers it will bring on a pair
  10. Aug 13, 2022 at 8:36 PM
    eon_blue
    Azusa, CA
    Damn... Sorry man, glad you guys were able to get there and be with her even for a few minutes before she passed, despite the rest of the family failing to do the right thing by not letting you know earlier. Our condolences to you and Steph
    Wulf and Kwikvette[QUOTED] like this.
  11. Aug 13, 2022 at 8:46 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    It's tough. It'll continue to be tough but just be there and and help get her the help she needs.
  12. Aug 13, 2022 at 9:17 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    How are the other ones failing? Curious if maybe they lack flyback diodes
  13. Aug 13, 2022 at 9:32 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    We’re not sure. All the inputs and even grounds of the solenoids are fused but they never pop. The one that failed today had completely burnt wires. And I think that bus all the fans were bad.
    The reason the fan setup is so janky is because these buses never had e-fans stock. It was one extremely large hydraulically driven fan factory. But the coach builder in Spain doesn’t make the hydraulic fan parts anymore so we were SOL and had to convert it.
  14. Aug 13, 2022 at 10:06 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  15. Aug 13, 2022 at 10:07 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Just get some M18 fuel jobsite fans
  16. Aug 13, 2022 at 10:23 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Are these fans not running on AC?
  17. Aug 13, 2022 at 10:39 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    No, they’re DC fans. They’re cooling a 14.9l Cummins engine on a 60 foot bus haha.
    I’ve never heard of AC fans on a vehicle, maybe industrial stuff uses like an inverter or something I don’t know about?
    Running Board Man likes this.
  18. Aug 13, 2022 at 11:02 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Oh it sounded like they were cooling some generator or something. AC fan speed is easy to control.. DC isn't hard if it's PWM
    BartMaster1234[QUOTED] and jubei like this.
  19. Aug 13, 2022 at 11:23 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    HVAC guys, can overcharging your system make it not cool as well?
    ie: topping off the truck when it's actually got the recommended mass of refrigerant already in it?
  20. Aug 13, 2022 at 11:26 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    It can reduce performance yes. If it’s enough, it can cause the pressure relief pop off too
    CS_AR and Running Board Man like this.
