  1. Sep 8, 2022 at 6:04 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  2. Sep 8, 2022 at 6:17 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Said no predator ever
    Kwikvette likes this.
  3. Sep 8, 2022 at 8:10 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  4. Sep 8, 2022 at 8:36 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  5. Sep 8, 2022 at 8:51 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @Wulf
    I'm gonna tackle the tubbing for 35s this month, any tips for chopping?
    jubei and Kwikvette like this.
  6. Sep 8, 2022 at 9:05 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :drool:
    Friend of mine just did that about a month ago, which reminds me I need to get my bottle of gas back
  7. Sep 8, 2022 at 9:07 AM
    Speedytech7
    I'm aware of whom you're referring to
    Kwikvette[QUOTED] likes this.
  8. Sep 8, 2022 at 9:24 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    :pout:
  9. Sep 8, 2022 at 9:25 AM
    Speedytech7
    You know I'm just gonna text you after I set fire to the carpet anyway
  10. Sep 8, 2022 at 9:29 AM
    Speedytech7
    Also I caught this beautiful moment, like a scene right outta Forrest Gump
    Digiratus and BartMaster1234 like this.
  11. Sep 8, 2022 at 9:30 AM
    m3bassman
    Green truck
    It's not the carpet, it's the open cell foam that's in the bottom corner that catches fire.
  12. Sep 8, 2022 at 9:31 AM
    m3bassman
    Green truck
    Bahahaha prancing through the continental divide! Reminds me to the intro to little house on the prairie.
  13. Sep 8, 2022 at 9:43 AM
    Wulf
    rock raisin
    Yassss, asking for anything in particular or just in general?
    Use the wheels/tires you plan on running for a long time, the offset/wheel width can change the angles and contact points at full lock.
    Take the struts out and move your alignment forward and back as much as possible when checking clearances. Don't forget that the bump itself can compress a little bit so even at full bump it may go further into the fender if you're bombing down a trail or dropping a ledge (i forgot this :bananadead:)
    You can probably get away with grinding the front lip of the body mount off without having to actually cut into it.
    As far as cutting goes, I took a piece of 1x2 and made a scribe so both front outer fenders got marked/cut the same amount.
    Cutting the inner fender/firewall sucks because of the factory undercoating, buy good cutting discs but not great ones. Id start cutting at the bottom and seeing where the tire line is, then cutting vertically to accommodate it.
    I tubbed close enough to the clutch pedal that I can't wear some boots and it still rubs on the outside lol
  14. Sep 8, 2022 at 9:47 AM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    I set my 99 on fire welding the fender apron and other random holes back together. Good times.
  15. Sep 8, 2022 at 9:48 AM
    Wulf
    rock raisin
    I came close lol, burned up a bath towel I was soaking in water to keep the back of the dash safe
    04Pre_Runner[QUOTED] likes this.
  16. Sep 8, 2022 at 9:48 AM
    Speedytech7
    What gauge of steel did you buy and how much do you think I should get? I'll probably unscrew the bumps and remove my fenders entirely since I have fiberglass to put on. Being able to just grind the body mount is good to know. I'll adjust my SPCs forward and back as much as possible when I cut it up.
    Wulf[QUOTED] likes this.
  17. Sep 8, 2022 at 9:54 AM
    m3bassman
    Green truck
    Fenders off is the way to go. Instead of fiddling with the alignment, just use the tire for clearance, then take a little extra. You'll want a new washer bottle and I would remove the airbox before you start hitting the fender with your purse on the bottom side.
    Wulf likes this.
  18. Sep 8, 2022 at 9:55 AM
    Wulf
    rock raisin
    I think I used 16 gauge, it was close to the factory thickness. I'll go measure at lunch and ballpark how much I used, I don't remember if a 2x4ft sheet was all I bought or not
    Also, I used 3M seam sealer inside and out and it has never leaked. I coated it with Rust-Oleum undercoat and it came out looking sneaky enough that most people don't notice it's tubbed unless they're familiar with 1st gens
    jubei likes this.
  19. Sep 8, 2022 at 9:57 AM
    Wulf
    rock raisin
    Oh yeah I had to take the fender intake tube off. i almost think I might need to close up the intake inlet and do the deck plate mod to keep the airbox from filling with sand.
  20. Sep 8, 2022 at 10:09 AM
    eon_blue
    Azusa, CA
    Our low was 85˚ last night :luvya:
    although there's a hurricane down by Mexico right now and we're starting to get the tail of it up here...little bit of rain this AM and more predicted for tomorrow and Saturday. Also cooling off quite a bit finally. Hope it stays that way but Sept is usually the 'heat wave' month for us.
    it's kind of weird to see how much it's been in the news all over considering how it's normally like this every year. I think the drought combined with growing fire risk is what makes it a bigger deal.
