  1. Oct 5, 2022 at 5:47 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    That guy had big ambitions. Then he found out how much steel cost. Love the cab vent. Gotta have air flow when racin. Bet that c-board is teal now.
    CS_AR likes this.
  2. Oct 5, 2022 at 5:56 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Ujoint changed probably need to do the other two sooner than later but it's fine.
    Kwikvette and Yota X like this.
  3. Oct 5, 2022 at 6:03 PM
    Yota X
    NW New Jersey
    1st gen
    Its always like that with maintenance.
    Kwikvette likes this.
  4. Oct 5, 2022 at 6:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  5. Oct 5, 2022 at 6:21 PM
    JKO1998
    Utah
    It was passed gone for sure, should probably just do the ujoints and carrier bearing
    But having no tools or space at school really puts a damper on that.
    Yota X[QUOTED] likes this.
  6. Oct 5, 2022 at 6:24 PM
    TACO_GUY03
    TACO_GUY03 Well-Known Member
    Houston, TX
    03 Tacoma Xtra-cab 4x4 v6
    I have a 2004 Tacoma and I plan to 4wd swap. So basically I found 1997 Tacoma with manual hubs. I was planning to get the knuckles, hubs and diff off the 97. The problem… the truck is manual would the transfer case work on a 2004 4wd auto tranny? I plan finding one after. Since I’ve heard 03-04 trannys are different.
  7. Oct 5, 2022 at 6:28 PM
    Yota X
    NW New Jersey
    1st gen
    Yeah, the best mechanics can't shine with just a crescent wrench. Not having the tools or space makes the easiest shit a pain in the ass. I recently tried to do a battery swap with channel locks. It was embarrassing.
  8. Oct 5, 2022 at 6:30 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You can basically use everything from said truck except the transfer case and transmission though...if you're in that deep, just go manual on your truck.
    If doing so, make sure your trucks engine and donors truck engine are the same.
    By the way, there are many, many threads covering 4x4 swaps with any and all listed parts, compatibility, etc.
    Do a search.
    TACO_GUY03[QUOTED] likes this.
  9. Oct 5, 2022 at 6:52 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Installed the first TRD lift on a turd gen tundra at work. $4000 kit. Oof. New axles, lower knuckle ball joint things, tie rods, shocks, front springs, rear spring spacer seat, brake lines, upper control arms..
    Honestly kinda impressive until you see the price
    But very nice geometry correction from this setup.
    [​IMG][​IMG]
    Yota X and TACO_GUY03 like this.
  10. Oct 5, 2022 at 6:55 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Why new axles though?...
  11. Oct 5, 2022 at 7:00 PM
    JKO1998
    Utah
    I've done 99% of my everything I've done to my trucks with stupid hand tools.
    I went to my aunts, boyfriends tonight and he brought the power tools, was nice.
  12. Oct 5, 2022 at 7:03 PM
    Empty_Lord
    Dan
    They’re beefier. Like noticeably thicker shaft. And they articulate better. At least on the rack
  13. Oct 5, 2022 at 7:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I mean...that's just odd that it's even a thing; should be the standard axles really.
    Good for Toyota though to rip more money out of consumers hands.
  14. Oct 5, 2022 at 7:05 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    The best part is if you damaged body panel it's cheap to replace.
  15. Oct 5, 2022 at 7:05 PM
    Wulf
    rock raisin
  16. Oct 5, 2022 at 7:05 PM
    Empty_Lord
    Dan
    Legally the dogs have to come off too.. so I’ve got some factory led fog lights I might fit in something. They’re just rectangle
    Whole bumper took like 10 minutes to get off. So they’re not terrible to work on I guess
  17. Oct 5, 2022 at 7:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I feel like some dude out there on the VW forums is like "what's the largest tire I can fit on my Jetta with no lift"
    Tour991 likes this.
  18. Oct 5, 2022 at 7:09 PM
    Tour991
    James
    South Reno/Tahoe
    Time for a BFH
  19. Oct 5, 2022 at 7:12 PM
    JKO1998
    Utah
    Could you ever run this vin
    5TEWN72N12Z898799
    the guy says he wants to know what options it has, fuel economy and shit.
    basically what would be on the sticker
  20. Oct 5, 2022 at 7:13 PM
    Wulf
    rock raisin
    That's after cutting the cab corners off and beating the firewall in a couple inches with the 5lb sledge lmao
