  1. Nov 28, 2022 at 1:59 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    01x4[QUOTED] likes this.
  2. Nov 28, 2022 at 2:01 PM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    Yeah agree, rear too
    Kwikvette likes this.
  3. Nov 28, 2022 at 2:04 PM
    01x4
    CS_AR and Kwikvette like this.
  4. Nov 28, 2022 at 2:43 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Mine can do appointments too. They're just booked 3 months out...
    When I got my DL renewed earlier this year, nobody was allowed in the building except those being helped. And no text alerts either. So I stood in line on the sidewalk for 2 hours. Next time Ill bring a camp chair.
    Sebz13[QUOTED], CS_AR and Kwikvette like this.
  5. Nov 28, 2022 at 3:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Sebz13[QUOTED] and 01x4 like this.
  6. Nov 28, 2022 at 3:33 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    One day back and I’m already ready to run back to the cabin
    CS_AR, Kwikvette and 01x4 like this.
  7. Nov 28, 2022 at 4:52 PM
    0xDEADBEEF
    @CS_AR
    Finally getting around to unpacking. Here's the trail we followed.
    See if you can spot the wrong turns :laughing:
    CS_AR likes this.
  8. Nov 28, 2022 at 4:53 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    @Tour991
    @Speedytech7
    @turbodb
    what besides basic tools/pick set is required for a shock rebuild?
    Besides spring compressor
    Just picked those other shocks up
  9. Nov 28, 2022 at 4:55 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Bench vise and some home made soft jaws helps, or you'll need some other way to hold the shock body while you work and fill. You'll need whatever spanners your shocks take to remove the wiper cap too. Everything else is just wipes and whatnot to clean with, new seals, and new oil.
    Tour991 and Kwikvette like this.
  10. Nov 28, 2022 at 5:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Jaxon Shock Services
    "Free before & after pics with every rebuild"
    Tour991 likes this.
  11. Nov 28, 2022 at 5:20 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Thanks for the GPX. I see it in Gaia. That's a slick-looking mapping tool that you are using.
    I highlighted the trail. I've not ventured into that area yet. My usual trails are shown on the map with a lot of pictures embedded in the route. I'm usually to the east and south of that area. The pictures are helpful with water crossings to have a reference when the water is up to know where the boulders are hiding.
    A few rains can completely change the way a trail looks.
    0xDEADBEEF[QUOTED] likes this.
  12. Nov 28, 2022 at 5:22 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Here's the step-by-step on the process; includes the tool list. There is also a version for King Shocks: Rebuilding/Revalving Smooth Body Shocks (ADS version)
    • Specialty tools
      • Branick 7600 spring compressor - used to compress the springs on coilovers, for removal.
      • - used to press spherical bearings in/out of the shock eye(s), though you can also use a sturdy vise for this task.
      • Shock / Reservoir Housing Wrench. Note: these are manufacturer specific.
      • Nitrogen Refill Kit, consisting of:
        • Nitrogen Regulator - 0-400 PSI
        • Nitrogen Fill Gauge - Lossless valve, and 0-300 PSI
        • Hose - to connect regulator and fill gauge
        • Nitrogen Tank - It's best to pick this up pre-filled at your local Airgas-style (or welding) supplier, but you can buy a 20 cubic-foot empty tank as well and get it filled.
        • A case (amazon) ( ) to store all the kit pieces in (optional).
      • Reservoir Piston Positioning Tool. Note: you can also (generally) use a 1/4" x 20 threaded rod in place of a special tool.
      • 18" Locking Surgical Clamps - or something long and narrow that can hole paper towels for cleaning shock and reservoir housings.
    jubei, Tour991 and Wulf like this.
  13. Nov 28, 2022 at 5:23 PM
    0xDEADBEEF
    100% agree on the water bit. I expect this would have been impassible, or at least more complicated, with more water. We saw a 'high water bypass' sign somewhere around where it crosses the buffalo riverbed, but it was dry so nbd, just made for some ups and downs and climbs out.
    CS_AR[QUOTED] likes this.
  14. Nov 28, 2022 at 5:23 PM
    eon_blue
    Azusa, CA
    and free information about the church of Utah
  15. Nov 28, 2022 at 5:24 PM
    0xDEADBEEF
    Paying for rebuild and getting that back would be shocking.
    Kwikvette and eon_blue[QUOTED] like this.
  16. Nov 28, 2022 at 5:24 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    What @Speedytech7 said. One thing i would add to the list is a schrader valve tool.
  17. Nov 28, 2022 at 5:24 PM
    CS_AR
    I highlighted the route that I took in Newton County on Sunday. The trails in that area are super easy to follow using the stock Gaia overland and MVUM overlays.
    I thought it was great and I didn't even get near the really beautiful part near Ponca.
  18. Nov 28, 2022 at 5:26 PM
    0xDEADBEEF
    That whole stretch is a blast from the water, and also absolutely gorgeous. I bet there were some great views from the trail too.
  19. Nov 28, 2022 at 5:31 PM
    CS_AR
    This was from the Erbie Campground. I'll go back to cross this as soon as the water clears up and I can see the concrete low-water bridge underneath it.
    Just a little too much current for a new crossing.
  20. Nov 28, 2022 at 5:34 PM
    0xDEADBEEF
    That would be fun on a kayak. :laughing:
