  1. Dec 8, 2022 at 5:43 AM
    Wulf
    Wulf no brain just damage
    rock raisin
  2. Dec 8, 2022 at 6:54 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    @Sperrunner got new ball joints on the way, looking to the end of this month to do them and front lift on the slug. no press is needed for the ball joints, correct? iirc they are just held in by the bolts and cauter pin. And i read just the spring re install will be the biggest pain to do
    CS_AR likes this.
  3. Dec 8, 2022 at 6:59 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Do yourself a huge favor and buy one of these for releasing the balljoint studs from their tapers. Oh and wear some safety equip when you use it, when the BJ pops loose the tool takes flight haha
    Das it mang[QUOTED] likes this.
  4. Dec 8, 2022 at 7:00 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    4:30 and that tire puts speedo accurate.
    CS_AR likes this.
  5. Dec 8, 2022 at 7:02 AM
    Wulf
    rock raisin
    Spending my whole paycheck on diesel this week but hey at least it's a fun drive
    jubei and CS_AR like this.
  6. Dec 8, 2022 at 7:02 AM
    Wulf
    rock raisin
    This is the way
  7. Dec 8, 2022 at 7:05 AM
    Speedytech7
    Where ya driving? Also is diesel coming down there at all, normal non-truckstop stations here have been stuck at 4.99 for a while when regular unleaded has fallen to 3.17 on average
    CS_AR and Das it mang like this.
  8. Dec 8, 2022 at 7:05 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    will do, applicable for the 5 lug correct? Gonna nab those and a cut off wheel for the shock. I think the coil spring compressor that goes in the middle of the spring works best but ill do more reading before
  9. Dec 8, 2022 at 7:08 AM
    Speedytech7
    Yeah, for just about any balljoint or tie rod end that tool is a real handy thing to have around. I'm not sure what the best tool for dealing with 5-lug springs is, the way I do similar chevies is kinda dangerous... my advice is to use a strap and hold your spring to the frame loosely when trying to get it out, that way if it jumps it doesn't come rocketing at you.
  10. Dec 8, 2022 at 7:16 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Welp woke up randomly at 4am bright eyed, Guess I'm going fishing.
  11. Dec 8, 2022 at 7:18 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    That’s the light layer of bondo where the molding holes were welded shut. It’s like fingernail deep
  12. Dec 8, 2022 at 7:19 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    I prefer this guy myself. Position it and hit it with the impact and all you get is a loud bang, not so much of a tool launcher.
    Feels like it every time I fill up my van, which thankfully is once a month and due to lack of a lot of trips has been about $100 a pop. Was $5.49/gal when I topped it off this morning. Best part is that running my furnace all night in it had not impact on overall fuel economy. Probably the 20min warming it up this morning was worse.
    Wulf[QUOTED] and Das it mang like this.
  13. Dec 8, 2022 at 7:21 AM
    Speedytech7
    I use that for some but they bend easily and don't fit the tie rod or the lower balljoint well. I use both with an impact though, either way its good fun, but I'd have two of the pitman arm pullers on hand for if one bends.... only ever used it to pull one pitman and it did great for that.
    Das it mang likes this.
  14. Dec 8, 2022 at 7:21 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Yeah the 5lugs are all bolted in.
  15. Dec 8, 2022 at 7:23 AM
    Empty_Lord
    Dan
    Nope. The rollover story is cool. The “I let it back into a Wall” isn’t. Procrastination on fixing the shift linkage issue has bit me.
  16. Dec 8, 2022 at 7:28 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    I'll swing by harbor freight shortly for a tool run then. That is smart smart, thanks zane! (I plan on doing the jack under LCA way and backing it out after putting the tool on) should happen towards the end of this month!
  17. Dec 8, 2022 at 7:28 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    Thanks miguel!
  18. Dec 8, 2022 at 7:29 AM
    m3bassman
    Green truck
    I have yet to break or bend mine thankfully.
    Parking brake is your friend regardless of automatic or manual. Of course, I say that with my tacomas e brake not connected. I put the acorn pin and safety pins that connect the linkage at the drum somewhere safe when I redid my leafs and now idk where that safe spot was...
    Wulf likes this.
  19. Dec 8, 2022 at 7:42 AM
    Empty_Lord
    Dan
    Usually I use the park brake. But this was a grab a couple tools and leave deal.
  20. Dec 8, 2022 at 8:02 AM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Yeah I’ve used the Grimm Jeeper calculator. I also know it’s slightly inaccurate once you factor in higher elevations and extra weight. The only reason I’m considering 4.56 is I already have an existing new front.
    Not too worried about speedo since I have a speed sensor calibration thing that attaches to the transfer case VSS harness.
