  1. Dec 23, 2022 at 10:46 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Ha, it's 46° inside. Don't think a candle is going to help. I have a couple of space heaters going. As long as I stay within 5' of them I'm fine.:oops:
  2. Dec 23, 2022 at 10:47 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Man, that sourdough starter is strong as hell
    Unwrapped it to feed it and that smell of alcohol hits you hard
    CS_AR and Wulf like this.
  3. Dec 23, 2022 at 10:54 AM
    Digiratus
    Roaming the PNW
    The RedHead
    This thing might not be fancy enough. I'm not seeing any lights.
  4. Dec 23, 2022 at 10:55 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Check the manual for the procedure to check but you have a Last Error button and a status LED I'm sure that will tell you whats wrong
    Wulf likes this.
  5. Dec 23, 2022 at 10:57 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    CS_AR, Kwikvette and Wulf like this.
  6. Dec 23, 2022 at 10:58 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    @Sperrunner OT
    jubei, Kwikvette and Speedytech7[OP] like this.
  7. Dec 23, 2022 at 11:02 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Sometimes there will be a little window in the panel positioned right in front of that status LED so it can be checked without removing the panel and engaging any lockouts.
    Not sure if yours has that or not, though. Regardless, sorry about the run of bad appliance luck!
    Wulf likes this.
  8. Dec 23, 2022 at 11:05 AM
    jubei
    NoCo
    Stuff. Also things.
    @Wulf
    Did I hear you’re lifting again? How’s it going for you? You getting where you want to go?
  9. Dec 23, 2022 at 11:09 AM
    Wulf
    rock raisin
    I'm in damage control mode after losing all my strength hahaha :homer:. I can still max 135-155ish squat/bench but am below that for for reps. RDL is decent and I can probably get back to 225 without a ton of work but building muscle is definitely way harder to do when I also am trying to drop another 30-50lb. Pretty low numbers for someone my size but hopefully enough to be able to wrench and deal with shit in the shop and on the trail if I need to.
    jubei[QUOTED] likes this.
  10. Dec 23, 2022 at 11:10 AM
    Wulf
    rock raisin
    @jubei have you seen that Walmart stocks bumper plates now? About $2lb
    jubei likes this.
  11. Dec 23, 2022 at 11:11 AM
    Digiratus
    Roaming the PNW
    The RedHead
    <frantically looking for the manual>
    There are what look like little view windows on each panel. I check them out. :itllbuffout:
    Wulf likes this.
  12. Dec 23, 2022 at 11:12 AM
    Wulf
    rock raisin
    If you have the model number maybe we can help you find a PDF of the manual :)
    Kwikvette and jubei like this.
  13. Dec 23, 2022 at 11:14 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Plows are out in formation around Fayetteville. I think this is on I49.
    Wulf likes this.
  14. Dec 23, 2022 at 11:15 AM
    Wulf
    rock raisin
    I'll take one of the two on the right
    CS_AR[QUOTED] likes this.
  15. Dec 23, 2022 at 11:16 AM
    CS_AR
    I didn't know we had anything plows like that.
    Wulf[QUOTED] likes this.
  16. Dec 23, 2022 at 11:25 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    [Pic request]
    Anyone have a picture with their suspension at full compression? Specifically looking for how high the UCA travels and the margin to the wheel well.
  17. Dec 23, 2022 at 11:25 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Looks like the had to go deep into the yard to fill out the formation. I wonder what those trucks do for a day job.
  18. Dec 23, 2022 at 11:26 AM
    CS_AR
    Something different no doubt. :thumbsup:
  19. Dec 23, 2022 at 11:26 AM
    jubei
    NoCo
    Stuff. Also things.
    Hey, good on you for getting back at it! That’s awesome! It’s never fun to start over again, but it sounds like you’re doing it and seeing improvement. If you’re trying to drop some body fat, it’s even tougher, for sure.
    I’m finally to a place where I can move weights that seem appropriate for an old guy my size, which is cool. But I 100% took advantage of the ‘getting strong’ phase and now I’m more fluffy than I’d like to be. Hoping to drop some fat over the next six months, but dreading feeling shitty and weak while I slog through it. So, I’ll be right there with you! Good luck!
    Did not know that. I’ll have to check it out. I have two pairs of Rogue 55lb training plates and love them for pulls.
    Wulf[QUOTED] and CS_AR like this.
  20. Dec 23, 2022 at 11:27 AM
    Speedytech7
    Depends on the arms, there is no clearance for SPCs, they'll scrape the top of the fender well and puncture it with the grease zerk
    treyus30[QUOTED] and Wulf like this.
