  1. Dec 23, 2022 at 11:29 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    CS_AR[QUOTED] and Wulf like this.
  2. Dec 23, 2022 at 11:32 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Found the manual and also saw the red flashing LED through the view window. The paper manual only says to call for service for any red flashing lights. A ggole search found a support page for the unit I have which says this for 7 flashes:
    CODE: 7 RED FLASHES
    RESULT: This fault code indicates that the flame could not be established. This no-light condition occurred 3 times (2 retries) during the call for heat before locking out.
    FIX: Low gas pressure, faulty gas valve, dirty or faulty flame sensor, faulty hot surface ignitor or burner problem may cause this. The furnace will lock out for one hour and then restart.
    I'm wondering if there could be an issue with the gas meter outside, Maybe it's frozen. :rofl:
    @Speedytech7 @jubei
    jubei and Wulf[QUOTED] like this.
  3. Dec 23, 2022 at 11:32 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Tour991 likes this.
  4. Dec 23, 2022 at 11:32 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I've got uniballs but I figured I could do a little mental math if I saw stock ones
  5. Dec 23, 2022 at 11:36 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    That sucks! I seem to remember ours doing something similar at the old house. Since it mentioned gas stuff, I punted and had the HVAC dudes fix it…
    Wulf likes this.
  6. Dec 23, 2022 at 11:36 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    It could be, any of the neighbors having a similar problem?
  7. Dec 23, 2022 at 11:37 AM
    Wulf
    rock raisin
    CS_AR likes this.
  8. Dec 23, 2022 at 11:37 AM
    Wulf
    rock raisin
    Yeahhh cutting after bulking isn't always the most fun hahaha. Do you do meal prep or anything like that to manage it?
  9. Dec 23, 2022 at 11:40 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm not sure, my meter hasn't frozen in the negatives before, so I can't imagine with only 30* yours would. I'd probably clean the flame sensor if I could verify gas flow, do you have another gas appliance like a dryer or something to see if it lights?
    Digiratus[QUOTED], jubei and Wulf like this.
  10. Dec 23, 2022 at 11:43 AM
    jubei
    NoCo
    Stuff. Also things.
    Nope haha! Not yet. After the holidays, I think that will be the only option. My only hope is that maybe this will be the last long, horrible, depressing, ‘cut’. If I can get to a place that’s easier to maintain, I can maybe just make small changes every few months at that point. That goal has been elusive for me my entire adult life, though haha.
    During this strength phase, the only thing I do consistently is some whey isolate protein to make sure I’m hitting my protein numbers. Beyond that, it’s all been pretty much eat what’s around :rofl:
  11. Dec 23, 2022 at 11:43 AM
    6P4
    Colorado Springs
    Tour991 and CS_AR[QUOTED] like this.
  12. Dec 23, 2022 at 11:45 AM
    jubei
    NoCo
    Stuff. Also things.
    Are you meal prepping and if so, is it working well for you?
  13. Dec 23, 2022 at 11:47 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, seems unlikely to me that it is the meter. I talked with 2 neighbors who are not having issues. I'm guessing it's something internal to the furnace. My other gas appliance is the dead water heater.
  14. Dec 23, 2022 at 12:15 PM
    Speedytech7
  15. Dec 23, 2022 at 12:28 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    That's the Gen X way.
    jubei likes this.
  16. Dec 23, 2022 at 12:56 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Adding to the fleet in 2023?
    Taco critter likes this.
  17. Dec 23, 2022 at 12:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So then...alcohol would be like steroids :anonymous:
    se7enine likes this.
  18. Dec 23, 2022 at 1:04 PM
    CS_AR
  19. Dec 23, 2022 at 1:05 PM
    CS_AR
    My youngest son is now officially engaged. I'm happy for them.
    Tour991, Taco critter and jubei like this.
  20. Dec 23, 2022 at 1:14 PM
    CS_AR
    Ohh man..
    Open a Go Fund Me for accessories and call it an FJ Cruiser. Some of you may have seen this.
