  1. Jan 14, 2023 at 7:02 AM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    CS_AR likes this.
  2. Jan 14, 2023 at 7:05 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Abraham yancer
    Abeyancer[QUOTED] likes this.
  3. Jan 14, 2023 at 7:34 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Kwikvette and Wulf[QUOTED] like this.
  4. Jan 14, 2023 at 7:35 AM
    Das it mang
    Az
    1996 T100 SR5 MT
  5. Jan 14, 2023 at 8:04 AM
    Wulf
    rock raisin
    Might never break 45mph but you'll never break down
    01x4 likes this.
  6. Jan 14, 2023 at 8:09 AM
    Wulf
    rock raisin
    @Speedytech7 @jubei did you cut the rear most front fender mount off when you tubbed?
    Trying to decide what I want to do to fix it. Might run a bracket off the lower door hinge idk
  7. Jan 14, 2023 at 8:09 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Milwaukee sure is a cult lol
    I was looking up cord grips, apparently elechickens get cold easily
    0xDEADBEEF[QUOTED] likes this.
  8. Jan 14, 2023 at 8:10 AM
    Abeyancer
    Jimmie
    PNW
    That also could very well for my Amish name
  9. Jan 14, 2023 at 8:12 AM
    Wulf
    rock raisin
    A swing and amish
    Yota X and Abeyancer[QUOTED] like this.
  10. Jan 14, 2023 at 8:13 AM
    Wulf
    rock raisin
  11. Jan 14, 2023 at 8:25 AM
    Wulf
    rock raisin
  12. Jan 14, 2023 at 8:30 AM
    Wulf
    rock raisin
  13. Jan 14, 2023 at 8:33 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The one at the bottom? No I left both of them, but I nearly cut the forward one in half, just barely left enough to thread a bolt into it.
  14. Jan 14, 2023 at 8:48 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Yeah, I didn’t end up with much more than an inch of fender down there and the OG mounting locations were long gone. For at least a month I or two, I literally ran a small piece of duct tape to keep the fender from flapping around :rofl:
    Eventually, I stacked tacks around a flange nut on the body side and drilled a hole in the fender that lined up with the nut so I could actually bolt it down. It’s held ever since. The nut was better than a rivnut because the nut stood off from the body just enough to make the body lines not look funky. Not that any of it looks great anyway :D
  15. Jan 14, 2023 at 9:43 AM
    Wulf
    rock raisin
    hehe that sounds perfect, I should dump out my spare hardware and see if I could do similar. I have had the bottom most fender hole zip tied to the cab mounts to keep it from flapping in the wind too much but it still rattles quite a bit
    jubei[QUOTED] likes this.
  16. Jan 14, 2023 at 9:45 AM
    Speedytech7
    Mine is entirely bolted down as it should be but they're fiberglass so it needs the tension from the bolt to stay in the right shape. I didn't have to cut quite as much of them since they don't contact the tire the way a stock fender would.
    Wulf[QUOTED] and jubei like this.
  17. Jan 14, 2023 at 9:56 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Das it mang[QUOTED] likes this.
  18. Jan 14, 2023 at 9:58 AM
    Wulf
    rock raisin
    Yuppp. Whatever the length increase from the shackle is you get half of as the lift lol
    Das it mang likes this.
  19. Jan 14, 2023 at 9:58 AM
    Speedytech7
    Das it mang[QUOTED] and Wulf like this.
  20. Jan 14, 2023 at 10:00 AM
    Wulf
    rock raisin
    Ahhh yeah you a fancy boi :D
    How did the paint turn out??
