  1. Jan 27, 2023 at 9:14 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's nuts.
    You got record of yours being done?
  2. Jan 27, 2023 at 9:15 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    mine had ~ 35 k on them from when I purchased upon swapping lmao
    Wulf[QUOTED] likes this.
  3. Jan 27, 2023 at 9:15 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    Just what the PO told me. He did all the work himself and seemed pretty competent. Only OEM parts were used.
    Kwikvette[QUOTED] and Wulf like this.
  4. Jan 27, 2023 at 9:16 AM
    Wulf
    rock raisin
    OEM 555 best OEM
  5. Jan 27, 2023 at 9:17 AM
    Wulf
    rock raisin
    these are beeeef
    I'm a heretic but I probably wouldn't go to all the work on a yota axle lol
  6. Jan 27, 2023 at 9:18 AM
    Wulf
    rock raisin
    I still have this diamond housing, I've thought about retubing it and turning it into a front but whyyyyy
    I woke up at 4 am today thinking I should start collecting SAS parts again lmaooo
  7. Jan 27, 2023 at 9:18 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The diamond you had didn't teach you anything? :p
    Kwikvette likes this.
  8. Jan 27, 2023 at 9:19 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Abeyancer and Wulf[QUOTED] like this.
  9. Jan 27, 2023 at 9:20 AM
    Wulf
    rock raisin
    hahaha i try and be nice when they come up. They do make some great products but I wouldn't buy any custom axle housing stuff from them. They're super hard to get a hold of.
  10. Jan 27, 2023 at 9:21 AM
    Wulf
    rock raisin
    It says " built to exceed OEM Specification", do you think they could just lie on their Amazon page like that?
  11. Jan 27, 2023 at 9:22 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
  12. Jan 27, 2023 at 9:22 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  13. Jan 27, 2023 at 9:25 AM
    Speedytech7
    Not unless the slip yoke is damaged, 11mm is just a hair over a centimeter, should have way more play in a slip yoke safely. My guess is improper pinion angle or the driveshaft came apart and they put it back together out of phase
    Wulf, Kwikvette and CS_AR[QUOTED] like this.
  14. Jan 27, 2023 at 9:26 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That'll be a back and forth back and forth adjustment routine I wouldn't want to mess with.
    Your buddy have adjustable uppers as well?
    Panhard bar relocation done? Since the axle is being moved, the panhard bar should be adjustable as well (would require a slightly longer length).
    CS_AR[QUOTED] likes this.
  15. Jan 27, 2023 at 9:26 AM
    CS_AR
    That's it. The pinion angle is supposed to be correct. Out of phase drive shaft could be it.
    Wulf likes this.
  16. Jan 27, 2023 at 9:27 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ooh aren't you having driveshaft issues yourself?
    I was thinking it was a combination of lift and the altering of the factory geometry that would introduce vibrations. Like you said, that difference is so minimal the slip yoke has plenty more to travel.
  17. Jan 27, 2023 at 9:28 AM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    Haven't been in an 80 in the snow, but the 100 was a blast.
    My AWD Express van that I camperized was also damn fun in the snow. I didn't have a heavy build, so tat was probably part of it, but good memories in that thing in the snow/ice.
  18. Jan 27, 2023 at 9:29 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Pics of said van? :drool:
    01x4[QUOTED] likes this.
  19. Jan 27, 2023 at 9:29 AM
    Wulf
    rock raisin
    Would it be thin or
    Would it be thick
    If I chose my dough tonight
    Chances are that I might
    Chicken wings on the side
    And I'm contemplating crispy fries
  20. Jan 27, 2023 at 9:29 AM
    CS_AR
    Don't know about adjustable uppers. I would use my chassis ear to zero in on the vibration.
    Kwikvette[QUOTED] likes this.
