  1. Jan 29, 2023 at 3:39 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    CS_AR, Wulf and Kwikvette like this.
  2. Jan 29, 2023 at 3:39 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    okay guys I’ll go look but it seems to be sealing fine
  3. Jan 29, 2023 at 3:40 PM
    Sebz13
    Shane
    Maui Hawaii
    The door gaskets what do you guys think seems fine right ? Also I ordered the wrong plug I think for the back I’m missing both sides
  4. Jan 29, 2023 at 3:41 PM
    Sebz13
    Shane
    Maui Hawaii
    I covered them with tape and we have some more rain coming so I’ll be watching to see where it leaks. I’m gonna run an extension cord and my dehumidifier I think on Tuesday to suck the rest of the water out.
  5. Jan 29, 2023 at 3:50 PM
    Wulf
    rock raisin
  6. Jan 29, 2023 at 3:51 PM
    Wulf
    rock raisin
    wired up the elocker pins that came apart and the bitch still doesn't work. Dunno why I keep wasting time on this axle.
    Ozark_RegCab likes this.
  7. Jan 29, 2023 at 3:53 PM
    Sebz13
    Shane
    Maui Hawaii
    my e locker light doesn’t come on but seems to work kinda. I wanna switch to a Toyota harness. Can you hear it engaging ?
  8. Jan 29, 2023 at 3:53 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Sperrunner[QUOTED] likes this.
  9. Jan 29, 2023 at 3:56 PM
    Wulf
    rock raisin
    nope, the motor doesn't run at all
  10. Jan 29, 2023 at 3:58 PM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    Mine looked fine too. If you dry out that area under your backseat where I'm guessing some water has settled, put the plug back in too, then hose down the rear window for a bit, that should tell you. I ended up replacing my window as well as the gasket and I used some silicone in a couple spots to just be safe. It was the most annoying leak to deal with. I ended up pulling the interior anyway and then could see the water rolling down the back of the cab which really confirmed it.
    Replacing a window and gasket isn't fun though, if you go that route just get a shop to do it. I won't do it again anyway haha.
    From what I could see your door seals look ok. Even with ripped old ones, no water gets in from there on mine.
  11. Jan 29, 2023 at 3:59 PM
    Wulf
    rock raisin
    I think i like bitching more than I like having working shit. I must because I keep spending time on junk instead of just moving on
  12. Jan 29, 2023 at 4:00 PM
    Sebz13
    Shane
    Maui Hawaii
    Thank you bro, I appreciate it. I’m gonna plug those holes and then I’m going to go pull hopefully two Toyota power steering pumps to replace my failing one. I’m too broke right now to get a new one so gonna try with these. When I’m at those trucks they are both extra cabs I’ll try and steal a gasket from em
    01x4[QUOTED] likes this.
  13. Jan 29, 2023 at 4:01 PM
    Sebz13
    Shane
    Maui Hawaii
    Is there a third party harness for it that works like stock? Does such a product exist ? I want my light to work when I lock it
  14. Jan 29, 2023 at 4:02 PM
    Abeyancer
    Jimmie
    PNW
    Flippin crazy, I can't believe that belt really does ride against the crankshaft Screenshot_20230129-160121_Chrome.jpg
    Wulf[QUOTED] likes this.
  15. Jan 29, 2023 at 4:03 PM
    Wulf
    rock raisin
    Kwikvette and Abeyancer[QUOTED] like this.
  16. Jan 29, 2023 at 4:05 PM
    Wulf
    rock raisin
    Lol, this is the Low Range off-road standalone elocker harness. It pulled wires out of the pins because they weren't well crimped so I popped the pins, re crimped, and put it back together. i dunno what's going on, I guess I should test the motor.
    Maybe I'll just spend $500 on the cable conversion for my sanity
  17. Jan 29, 2023 at 4:08 PM
    Sebz13
    Shane
    Maui Hawaii
    Building my downstairs for me to live in is taking priority over the truck. I would have moved in already but the noise from upstairs was too much, so just spent a metric fuck ton of money on
    2x4 framing
    Insulation
    Hat channel 20 ga on the framing
    Another layer of insulation
    RSIC-1 clips at @5 dollars a pop x 80
    20 sheets of 5/8 quietrock at 75 a sheet
    30 tubes of green glue at 30 a tube
    20 sheets of 5/8 regular drywall at 30 a sheet
    8 tubes of acoustic sealant to seal the corners of each sheet
    8 sheets of acoustic puddy to wrap the gang boxes for the lights
    Tons of mud.
    Plus a week and a half of 100 dollars an hour x8 x7 for labor of two dudes.
    So pretty broke right now
    Wulf likes this.
  18. Jan 29, 2023 at 4:09 PM
    Sebz13
    Shane
    Maui Hawaii
    that sounds like a nightmare
    makes me want to go pull a harness from another truck
  19. Jan 29, 2023 at 4:11 PM
    Wulf
    rock raisin
    there are zero signs my truck has been leaking oil :laughing:
  20. Jan 29, 2023 at 4:16 PM
    01x4
    Yeah man good luck.
    Just FYI, I did have water along the sides of the doors as well (under the plastic piece) so that had originally confused me. But it was the water coming in from the rear window rolling down the back and then going down the sides as well. You can see in the photos, a lot of my little steel pieces back there had rusted from the water that had been subtly coming in over the years.
    Where the cushion is bolted down top center of the back
    Lower part of the backseat area where the seat hardware connects
    Then water would sneak down these wire routing grooves alongside the doors...go the whole way to the front carpet area on super heavy storms
    04Pre_Runner likes this.
