  1. Jan 31, 2023 at 7:04 PM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    Agreed 100%
  2. Jan 31, 2023 at 7:05 PM
    01x4
  3. Jan 31, 2023 at 7:06 PM
    eon_blue
    Azusa, CA
    Holy fuck $60k LOL
    04Pre_Runner and 01x4[QUOTED] like this.
  4. Jan 31, 2023 at 7:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Sell your 4R and buy that one :burp:
    01x4 likes this.
  5. Jan 31, 2023 at 7:07 PM
    eon_blue
    Azusa, CA
    I'll sell it for $70k and come out on top
  6. Jan 31, 2023 at 7:08 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    NO LOWBALLERZ INOWUTIGOT
    01x4 and eon_blue[QUOTED] like this.
  7. Jan 31, 2023 at 7:12 PM
    01x4
    I saw a 2021 Cruiser today listed at $125K. People are crazy.
  8. Jan 31, 2023 at 7:50 PM
    Running Board Man
    Running Board Man Well-Known Member
    For 60k you don't even get a tbu
  9. Jan 31, 2023 at 7:59 PM
    Running Board Man
    Screenshot of the tstat used in the listing doesn't show a jiggle valve, likely aftermarket garbage
    Paper gasket for the water pump too... defo aftermarket garbage
    04Pre_Runner, treyus30 and Yota X like this.
  10. Jan 31, 2023 at 8:10 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    When I used to get the ebay kits they were always toyota shit. $300 ish I think for a tbelt kit but came with everything.
  11. Jan 31, 2023 at 8:13 PM
    Yota X
    NW New Jersey
    1st gen
  12. Jan 31, 2023 at 9:10 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    @Wulf did you figure out if the driveshaft halves in my garage are useful to you?
  13. Jan 31, 2023 at 9:38 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    JKO1998 likes this.
  14. Jan 31, 2023 at 9:59 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I don't understand why he did it but it's neat
    Abeyancer[QUOTED] likes this.
  15. Jan 31, 2023 at 10:20 PM
    Wulf
    rock raisin
    U said it was the rear sections of the rear shaft?
    If I understand what I've found online correctly I could use both flanges to make a shaft for the 85
  16. Jan 31, 2023 at 10:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Here you go.
    https://carsandbids.com/auctions/rN1MwNR4/1996-toyota-tacoma-lx-xtracab-4x4
    Looks all original. I'm guessing it'll go for $15K.
  17. Jan 31, 2023 at 11:11 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    My 04 had a water pump/timing belt job done in ~2016 before I knew how to work on cars.
    Fan bracket was missing a nut, paper gasket, they ground down the mating surface of the water pump taking material off the block, and other oddness. Original idler, tensioner bearing, and auto tensioner, as expected. Gates water pump, belt, and thermostat with no jiggle valve.
    I’ve scraped at that paper gasket for over an hour and there is still some baked on the block. Bought the specific Toyota FIPG for coolant and I’ll be using a bit more than called for in the FSM. Hopefully it seals with all the imperfections.
  18. Feb 1, 2023 at 3:07 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    I’m going to go pull parts off a Tacoma tomorrow. Excited that’s a rare thing on my island the trucks never last in part outs people horde
  19. Feb 1, 2023 at 8:23 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  20. Feb 1, 2023 at 8:25 AM
    Wulf
    rock raisin
    things are going off the rails today huh
    Running Board Man likes this.
