  1. Feb 1, 2023 at 10:14 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    *looks at powerpack i designed :anonymous:
  2. Feb 1, 2023 at 10:14 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Power that expensive down there now?
  3. Feb 1, 2023 at 10:17 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    It is when it's 0.1 to 0.2kW x 24 x $0.15avg x 365 per year
  4. Feb 1, 2023 at 10:20 PM
    Speedytech7
    .15 is high ouch. I don't remember it being that bad when I was there, but I guess since you basically live where it's uninhabitable you have to factor in running your life support air conditioner all the time into the base rate. I don't ever cross the threshold of our low rate here into the higher rate so I'm only .07
    Wulf and Kwikvette like this.
  5. Feb 1, 2023 at 10:24 PM
    Abeyancer
    Jimmie
    PNW
    Zero insulation and leaky walls mean we have to run electric heat all winter and ac for summer but neither are on high blast. We just fall over into some of our power getting charged at .11
    Wulf and Speedytech7[QUOTED][OP] like this.
  6. Feb 1, 2023 at 10:25 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I'd have to get you the exact number - might be more like .10-.11 actually. But I never got an avg power value for my NAS either. I could also just not use it in peak summer time. Needless to say though, has some non-idealities that just puts it now comparable to Netflix imo, not the clear winner
  7. Feb 1, 2023 at 10:39 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Agreed. As far as power goes, VFD's can be finicky. Most of the devices/systems in these "mission critical" environments operate in an N+1 or N+2 configuration. Instead of having a backup VFD for a pump, they'll just have 3 independent VFD/pump systems. It's not uncommon for us to have 3 systems when only one is needed for fully loaded operations. Leaves one for operation, one for standby and one de-energized for maintenance etc.
    jubei and Abeyancer like this.
  8. Feb 1, 2023 at 10:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    .093712 for us. Yours is cheap.
    Abeyancer likes this.
  9. Feb 1, 2023 at 11:48 PM
    Wulf
    rock raisin
    don't thank me til it's over :p
    Sebz13[QUOTED] likes this.
  10. Feb 2, 2023 at 12:07 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    I’m shivering in my boots . :anonymous:
    Breaking my 23/1 fast with stek and eggs. Admittedly I wanted rare but I’m full tilt on gin so I over cooked it
    jubei, Abeyancer and Wulf[QUOTED] like this.
  11. Feb 2, 2023 at 12:49 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Yeah its held up pretty good for me so far. Especially just leaveing my ebike on it 24/7. Has held up great
    6P4[QUOTED] and Wulf like this.
  12. Feb 2, 2023 at 1:05 AM
    Wulf
    rock raisin
    hmmm that sounds p good right now
  13. Feb 2, 2023 at 1:29 AM
    Wulf
    rock raisin
    @Sperrunner thanks again for helping me with the heat pump install, it's running great:)
  14. Feb 2, 2023 at 2:03 AM
    Wulf
    rock raisin
    I missed my chance to beat you to saying it huh
    Taco critter likes this.
  15. Feb 2, 2023 at 2:39 AM
    Wulf
    rock raisin
  16. Feb 2, 2023 at 4:46 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Run the generators in the summer to sell power back to the city during peak load. We have about 6 or 8 of these bad boys hooked to the UPS. upload_2023-2-1_9-6-59.jpg
    These look small but the same idea.
    Gen1FTMFW[QUOTED] likes this.
  17. Feb 2, 2023 at 6:02 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Thanks for the recommendation, Facebook....
    Wulf likes this.
  18. Feb 2, 2023 at 6:38 AM
    Speedytech7
    I mean, it's on a 5 lug at least
  19. Feb 2, 2023 at 6:40 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Should ask him for the snail shown behind it...
  20. Feb 2, 2023 at 6:43 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Note to self, do not try to sync 70,000 text files with OneDrive.
