  1. Feb 5, 2023 at 4:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Throw in solid axle cause, you know..."while you're in there"
    Wulf[QUOTED] likes this.
  2. Feb 5, 2023 at 4:42 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    quick and easy front 3 link, no problem
    Honestly the TG kit is a deal, they figure out all the hard shit so u don't have to hahahaha
    Abeyancer and Kwikvette[QUOTED] like this.
  3. Feb 5, 2023 at 4:52 PM
    Wulf
    rock raisin
  4. Feb 5, 2023 at 4:57 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Did you charge extra for that loaf of snow on the roof?
    Wulf and Tour991[QUOTED] like this.
  5. Feb 5, 2023 at 4:58 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    No I insisted he take it with them. I have way to much here.
    Abeyancer, 6P4[QUOTED] and Wulf like this.
  6. Feb 5, 2023 at 5:01 PM
    6P4
    Colorado Springs
    Tour991[QUOTED] likes this.
  7. Feb 5, 2023 at 5:05 PM
    Running Board Man
    Running Board Man Well-Known Member
    In an accident or even just hard braking will bend that cross bar it's aluminum and the only structural member across the bed on (at least 2nd gens) those newer trucks
    Abeyancer likes this.
  8. Feb 5, 2023 at 5:07 PM
    Wulf
    rock raisin
  9. Feb 5, 2023 at 5:07 PM
    Running Board Man
    This is genius
    treyus30[QUOTED] likes this.
  10. Feb 5, 2023 at 5:15 PM
    6P4
    Colorado Springs
    Well I'll be... I like it. This guy did some real work. 322364877_1214599896091813_4321944960080_92854dcc26439c9f7e7efdef861d75777dbc6db6.jpg
    322136398_695718065600620_32835295096180_9b92e4bb50315ecd0eac68ac976eab376995edad.jpg
  11. Feb 5, 2023 at 5:23 PM
    Tour991
    James
    South Reno/Tahoe
    I love the 1st one.
    I'm thinking of putting the 3.4 from my white parts truck in my regular cab.
    I also need to swap in the trd locker axle on the 97 after I get it regeared.
  12. Feb 5, 2023 at 5:27 PM
    6P4
    Colorado Springs
    Huh, the first is the one I thought you'd be least interested in, given the condition.
    If I had your resources (space, skills, parts collection), I'd buy the red one and plop an engine in. Maybe a turbo 2RZ just for fun, since my current truck is already a clean/solid driver. 5VZ would also be fun, especially since you already have the parts.
  13. Feb 5, 2023 at 5:35 PM
    Tour991
    James
    South Reno/Tahoe
    I guess I have a thing for green regular cabs. Plus I could easily splice in the rust free frame.
  14. Feb 5, 2023 at 6:19 PM
    Wulf
    rock raisin
    I like it
    04Pre_Runner likes this.
  15. Feb 5, 2023 at 6:29 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    "Bolt-on friendly"
    "Plug n play"
    :burp:
  16. Feb 5, 2023 at 6:29 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    He's aware it's a composite bed.
    He's aware the rail isn't structural.
    He wanted it to hold his wheel; he's not a desert runner or anything.
  17. Feb 5, 2023 at 6:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Wulf
    Thanks for your gift!
    Interesting color and decal choice :rofl:
    Wulf and unstpible like this.
  18. Feb 5, 2023 at 6:33 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Swiped this bad boy up; normally found at auction for 3.2 - 3.7mil but the seller didn't raise the minimum bid.
    I waited until the last minute and swiped it for cheap.
  19. Feb 5, 2023 at 6:35 PM
    Running Board Man
    Found some identical replacement injectors for my 450, found the bad one and swapped it
    Runs like new
    Wulf, Abeyancer and 04Pre_Runner like this.
  20. Feb 5, 2023 at 6:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Relatively smooth and easy so far.
    I am fine with this with 2 considerations. First,verify with me beforehand that I have it on the insurance. The plan is to do that once Ben gets custody. Second, be gentle with the clutch. I've witnessed how you tend to twist driveshafts. No dropping the clutch at 4K please. :luvya:
